Gcode initiated pause
Posted by Replace
July 21, 2016 10:53AM
I want to insert a Gcode to pause the print, so I can change filament.
I want the extruder to stay heated, as well as the bed.
Maybe home the X, to avoid droop on the object....
My Machine runs on RAMPS on Arduino, with Repetier firmware and Repetier Host a controller
In the reprapwiki on Gcode, I find M226
However, it states repetier not supported.
Should I do something else ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Gcode initiated pause
July 27, 2016 02:29PM
Noboddy ?
November 17, 2016 02:22AM
Since you print using host use the host pause feature. Add
;@pause change filament
where you want the pause. Does not work with sd print.
