slicing time sooooo long oO
Posted by valerian
September 10, 2016 03:58PM
Hello !
I try to slice some pieces a little complex and I need lot of support material (pva with double hotend). but whenever there is a little too much support material the slicing time explodes. For example I'm trying to slice a little motorbike ( 15cm ) and the "progress line" seems blocked at "generate support material", not just 30min, but 6h or after a night!
I've got a good pc with gtx, i7... so, I don't understand :/
thanks in advance for yours answers smiling smiley
Re: slicing time sooooo long oO
October 14, 2016 11:45PM
and your hard drive ? is it solid state drive if not get one you will be amazed at the results
November 17, 2016 02:26AM
Check ram usage. If your ram usage exceeds ram you start to swap out memory you get really slow. Also avoid crossing perimeters seems to have great impact on speed for slic3r.
January 31, 2017 01:30PM
Can you post your STL, so others may check slicing?
