Hi Folks,
posting here and repetier sections.
Repetier-host 1.6.2 + slic3r 1.2.9
I'm attempting to print a microscope adaptor - essentially a tube with a flange and some fancy bits at the top.
Downloaded the part from thingyverse, prints just fine, but dimensions are off.
slice, adjust, make whole and go again...
except now the slicing does not work.... either the tube is filled in, or the support and part meld into each other with unexpected parting lines at the flange...
much weirdness.
same settings for slic3r on both parts.
things I've tried.
inverting the normals.
repair in netfabb basic
OBJ and STL
recalculating the normals. reversing the spiral, redoing from scratch with different approaches...
TBH, I suspect it's not a Slic3r thing... but I've run out of ideas to try...
