Garage to cold ?
Posted by Replace
Garage to cold ?
January 19, 2017 01:17AM
Currently,
my garage is to cold to have Repetier Host start my heatbed.
It is probably somewhere around zero centigrade, but the bed temperature states -3
The heatbed icon disapprears immediately after connecting.
When I pre-heat the bed a few degrees with a hair drier, it will come-up and i can toggle it to heat.
After that all's fine.
I see no specific positive in this.
Is it a parameter ? Can I bypas that ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Garage to cold ?
January 19, 2017 05:26PM
There is a minimum temp setting in the firmware, normally this is used to detect a disconected thermistor
January 20, 2017 05:27AM
So, if I set this to minus 10,
It will startup ?
January 20, 2017 09:12AM
Replace
It will startup ?
yep that should work
