multiple gcodes in a row which get printed after each other
Posted by Highpressuresteam
August 17, 2017 05:44AM
I use the repetier host software it is nice and easy to work with!
is there a possibility like a plugin or something like that for series print ?
Like a list with multiple gcodes in a row which get printed after each other?
You come back to your printer after a day and it made the parts you put in the list?
In between the Software or the printer gives a signal to an arduino to control a fan and a part eject unit ?
is there something like that or any idea how to realize that ?
best regards
Christoph
Re: multiple gcodes in a row which get printed after each other
August 17, 2017 10:04AM
How are you going to remove the printed part to free up the bed for the next print if you are not with the printer.
If the parts are small enough, better to load multiple pats on the bed before you slice them, and print all at the same time.
January 08, 2019 07:01AM
If the space is big enuff ( X Y Z )you can select print individual part and print
