Probe like the BLTouch working with Repetier? June 12, 2018 09:15PM |
Re: Probe like the BLTouch working with Repetier? June 13, 2018 03:51AM |
Re: Probe like the BLTouch working with Repetier? June 13, 2018 05:42AM |
Re: Probe like the BLTouch working with Repetier? June 16, 2018 10:18AM |
Re: Probe like the BLTouch working with Repetier? June 17, 2018 10:05PM |
Re: Probe like the BLTouch working with Repetier? June 21, 2018 02:36PM |
Re: Probe like the BLTouch working with Repetier? June 22, 2018 04:17PM |
Re: Probe like the BLTouch working with Repetier? June 22, 2018 06:56PM |
obewan
You still need to set the X and Y offsets for the probe position in relation to the nozzle otherwise the firmware can not compensate for probing positions.
Is the prone in front or behind the nozzle, and how many mm ?
Is the probe to the left or the right of the nozzle and how many mm ?
Re: Probe like the BLTouch working with Repetier? June 23, 2018 08:23PM |
Re: Probe like the BLTouch working with Repetier? June 24, 2018 11:10AM |
Re: Probe like the BLTouch working with Repetier? June 24, 2018 12:03PM |
obewan
Try just selecting one language so it defaults to it.
I see you have selected generic therimstor table 1, have you created your own table for this ? better to select one of the pre set thermistors for bed and extruder.
Changing monitoring state from "Offline" to "Detecting serial port" Serial port list: ['/dev/ttyACM0'] Connecting to: /dev/ttyACM0 Changing monitoring state from "Detecting serial port" to "Opening serial port" Connected to: Serial(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Starting baud rate detection Changing monitoring state from "Opening serial port" to "Detecting baudrate" Trying baudrate: 115200 Send: N0 M110 N0*125 Recv: start Changing monitoring state from "Detecting baudrate" to "Operational" Recv: InfoowerUp Send: N0 M110 N0*125 Recv: Detected EEPROM version:19 Recv: Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000 Recv: Free RAM:83864 Recv: Card successfully initialized. Recv: SelectExtruder:0 Recv: FlowMultiply:100 Recv: ok Send: N1 M115*39 Recv: ok 1 Send: N2 M21*18 Recv: FIRMWARE_NAME:Repetier_1.0.2 COMPILED:Jun 24 2018 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3 Recv: CapROGRESS:1 Recv: Cap:AUTOREPORT_TEMP:1 Recv: Cap:EEPROM:1 Recv: Cap:AUTOLEVEL:1 Recv: Cap:Z_PROBE:1 Recv: CapOFTWARE_POWER:0 Recv: Cap:TOGGLE_LIGHTS:0 Recv: CapAUSESTOP:1 Recv: CapREHEAT:1 Recv: Printed filament:610.02m Printing time:4 days 16 hours 29 min Recv: PrinterMode:FFF Recv: ok 2 [...] Recv: Card successfully initialized. Recv: ok 3 Send: N4 M115*34 [...] Recv: ok 4 Send: N5 M21*21 Recv: FIRMWARE_NAME:Repetier_1.0.2 COMPILED:Jun 24 2018 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3 Recv: CapROGRESS:1 Recv: Cap:AUTOREPORT_TEMP:1 Recv: Cap:EEPROM:1 Recv: Cap:AUTOLEVEL:1 Recv: Cap:Z_PROBE:1 Recv: CapOFTWARE_POWER:0 Recv: Cap:TOGGLE_LIGHTS:0 Recv: CapAUSESTOP:1 Recv: CapREHEAT:1 Recv: Printed filament:610.02m Printing time:4 days 16 hours 29 min Recv: PrinterMode:FFF Recv: ok 5 Send: N6 M20*23 Recv: Card successfully initialized. Recv: ok 6 Recv: Begin file list Send: N7 M155 S2*100 Recv: Adjustable BLTouch Support 767079 Recv: spout_small_with_threads_n 1452250 Recv: BLTouch_auto_bed_levelling 180670 Recv: BLTouchMount (1).gcode 168534 Recv: End file list Recv: ok 7 Send: N8 M155 S2*107 Recv: ok 8 [...]
Re: Probe like the BLTouch working with Repetier? June 24, 2018 03:28PM |
Re: Probe like the BLTouch working with Repetier? June 24, 2018 04:02PM |
Re: Probe like the BLTouch working with Repetier? June 24, 2018 07:17PM |
