I do not set temp in the code, so I will manual heat the extruder in repeater host and the bed to the desired temp.
When reached, I will start the print.
The last time, often I walk away from the pre heating, as It will take some time. When I expect all has reached the temp, I return.
And now often I see the lcd has the error ' def'. and all heaters are off.
So I reset the board, reconnect the printer and do it again. Than it will work.
What is the def error ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
