Re: Mendel en Rosario February 21, 2014 09:38PM |
Re: Mendel en Rosario February 21, 2014 09:42PM |
Re: Mendel en Rosario February 21, 2014 09:45PM |
Re: Mendel en Rosario February 21, 2014 09:46PM |
Re: Mendel en Rosario February 21, 2014 09:47PM |
Re: Mendel en Rosario February 21, 2014 09:54PM |
Re: Mendel en Rosario February 21, 2014 09:58PM |
Re: Mendel en Rosario February 22, 2014 06:26AM |
Re: Mendel en Rosario February 22, 2014 08:03AM |
poroto151
BUEN DIA.
RESPECTO AL HOTEND, COMPRE UN MAGMA IMPORTADO.
HECHO LAS MEDICIONES DEL CASO, PUDE VERIFICAR QUE LA ROSCA DEL CAÑITO DE ACERO INOXIDABLE (6MM) ES CONICA Y NO RECTA. LO CUAL ES ALGO LOGICO, POR CUANTO AL AJUSTARSE CON EL BARREL DE ALUMINIO CREA UN SELLAMIENTO QUE EVITA QUE CHORREE EL PLASTICO LIQUIDO. AL SER ROSCA CONICA COMPLICA LA FABRICACION CASERA DEL MISMO. ESTOY VIENDO SI PUEDO ENCONTAR MACHO DE ROSCAR PARA EFECTUAR LA ROSCA HEMBRA EN EL BARREL DE ALUMINIO. LA ROSCA EN EL TUBO DE ACERO INOXIDABLE DEBE SER HECHO EN TORNO CON PLAQUETA DE CORTE DE METAL DURO. VEO QUE EL TEMA DE ROSCA CONICA EN EL HOTEND NO ESTA MUY COMENTADO EN INTERNET. NO ESTA EN MIS POSIBILIDADES VERIFICAR QUE LOS QUE FABRICAN EN ARGENTINA TIENEN ESE TIPO DE ROSCA (ROSCA CONICA) EN EL HOT END.
Re: Mendel en Rosario February 22, 2014 09:59AM |
Re: Mendel en Rosario February 26, 2014 07:50PM |
Re: Mendel en Rosario February 27, 2014 07:53PM |
Re: Mendel en Rosario February 27, 2014 08:06PM |
Re: Mendel en Rosario February 27, 2014 08:08PM |
Re: Mendel en Rosario March 01, 2014 12:22PM |
Re: Mendel en Rosario March 01, 2014 02:17PM |
Re: Mendel en Rosario March 06, 2014 06:12PM |
Re: Mendel en Rosario March 08, 2014 04:12PM |
Re: Mendel en Rosario March 08, 2014 06:01PM |
Re: Mendel en Rosario March 08, 2014 06:12PM |
Re: Mendel en Rosario March 08, 2014 06:58PM |
Re: Mendel en Rosario March 08, 2014 07:04PM |
Re: Mendel en Rosario March 08, 2014 07:25PM |
Re: Mendel en Rosario March 08, 2014 07:26PM |
Re: Mendel en Rosario March 08, 2014 08:12PM |
Re: Mendel en Rosario March 09, 2014 12:12AM |
No es tanto calentura che, en parte es que no me cierra tener las varillas de la medida correcta y que la superficie cubierta de la cama por el hotend parezca menos a las especificaciones que encuentro, me da idea que algo hice malQuote
Pointless
No te calientes tanto luis, MUY pocas veces vas a necesitar los 20cm...
layoroa
Mmmm, sospecho que deben ser los INA alemanes que vende migniani?.. Me imagino que si vas a usar semejante rodamientos los vas a acompañar con unas varillas super recontra calibradas de 8mm....
Re: Mendel en Rosario March 09, 2014 06:47PM |
Re: Mendel en Rosario March 09, 2014 08:50PM |
Re: Mendel en Rosario March 09, 2014 09:20PM |
Pointless
Porque usarias full steps? mandale los 16 microsteps por step, los motores se mueven MUCHO mas fluido con microstepping
Re: Mendel en Rosario March 10, 2014 02:30AM |
