[Problema] Full graphic smart controller
Posted by manuel19941
June 02, 2014 11:40AM
Hola gente! Pude hacer andar mi pantalla LCD, pero tengo un problema con el boton, le cuesta entrar al menu, no entiendo por que, y no siento que no ande el "click" porque la pantalla reacciona al mismo y cuando logro entrar, al seleccionar la opcion de salir del menu, sale al primer click.
No entiendo que puede estar pasando, les adjunto un video de mi problema:
VIDEO
// ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com]
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// The RepRapWorld REPRAPWORLD_KEYPAD v1.1
// [reprapworld.com]
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click
// The Elefu RA Board Control Panel
// [www.elefu.com]
// REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARUDINO library folder: [github.com]
//#define RA_CONTROL_PANEL
//automatic expansion
//#if defined (MAKRPANEL)
// #define DOGLCD
// #define SDSUPPORT
// #define ULTIPANEL
// #define NEWPANEL
// #define DEFAULT_LCD_CONTRAST 17
//#endif
#if defined (REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER)
 #define DOGLCD
 #define U8GLIB_ST7920
 #define SDSUPPORT
 #define REPRAP_DISCOUNT_SMART_CONTROLLER
#endif
#if defined(ULTIMAKERCONTROLLER) || defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL)
 #define ULTIPANEL
 //#define NEWPANEL
#endif
//#if defined(REPRAPWORLD_KEYPAD)
//  #define NEWPANEL
//#endif
//#if defined(RA_CONTROL_PANEL)
// #define NEWPANEL
// #define LCD_I2C_TYPE_PCA8574
// #define LCD_I2C_ADDRESS 0x27   // I2C Address of the port expander
//#endif
//I2C PANELS
//#define LCD_I2C_SAINSMART_YWROBOT
//#ifdef LCD_I2C_SAINSMART_YWROBOT
  // This uses the LiquidCrystal_I2C library ( [bitbucket.org] )
  // Make sure it is placed in the Arduino libraries directory.
 // #define LCD_I2C_TYPE_PCF8575
 // #define NEWPANEL
//#endif
// PANELOLU2 LCD with status LEDs, separate encoder and click inputs
//#define LCD_I2C_PANELOLU2
//#ifdef LCD_I2C_PANELOLU2
  // This uses the LiquidTWI2 library v1.2.3 or later ( [github.com] )
  // Make sure the LiquidTWI2 directory is placed in the Arduino or Sketchbook libraries subdirectory.
  // (v1.2.3 no longer requires you to define PANELOLU in the LiquidTWI2.h library header file)
  // Note: The PANELOLU2 encoder click input can either be directly connected to a pin
  //       (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
  //#define LCD_I2C_TYPE_MCP23017
 // #define LCD_I2C_ADDRESS 0x20 // I2C Address of the port expander
 // #define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD
 // #define NEWPANEL
//#endif
// Panucatt VIKI LCD with status LEDs, integrated click & L/R/U/P buttons, separate encoder inputs
//#define LCD_I2C_VIKI
//#ifdef LCD_I2C_VIKI
  // Note: The pause/stop/resume LCD button pin should be connected to the Arduino
  //       BTN_ENC pin (or set BTN_ENC to -1 if not used)
 // #define LCD_I2C_TYPE_MCP23017
 // #define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD (requires LiquidTWI2 v1.2.3 or later)
 // #define NEWPANEL
//#endif
#ifdef ULTIPANEL
  #define NEWPANEL  //enable this if you have a click-encoder panel
  #define SDSUPPORT
  #define ULTRA_LCD
  #ifdef DOGLCD // Change number of lines to match the DOG graphic display
    #define LCD_WIDTH 20
    #define LCD_HEIGHT 5
  #else
    #define LCD_HEIGHT 4
  #endif
#else //no panel but just lcd
  #ifdef ULTRA_LCD
  #ifdef DOGLCD // Change number of lines to match the 128x64 graphics display
  #else
    #define LCD_WIDTH 16
    #define LCD_HEIGHT 2
  #endif
  #endif
#endif
// default LCD contrast for dogm-like LCD displays
#ifdef DOGLCD
# ifndef DEFAULT_LCD_CONTRAST
#  define DEFAULT_LCD_CONTRAST 32
# endif
#endif
Edited 1 time(s). Last edit at 06/02/2014 12:14PM by manuel19941.
Re: [Problema] Full graphic smart controller
June 02, 2014 12:12PM
Hola manuel!
Lo que suele pasar es que el switch genera un rebote (suerte de doble click) cuando lo presionas. El segundo click, desafortunadamente, te cae en la primer opción del menú que justamente es "Info screen..".
Proba apretando el boton sin soltarlo.
Adicionalemente te recomiendo que cuando pegues texto de tipo configuración o código en algún post, aplicarle el tipo "formatted code" (quinto ícono contando de derecha a izq). De este modo es más fácil su lectura.
Este es un
ejemplo
Saludos.-
Edited 1 time(s). Last edit at 06/02/2014 12:22PM by epoxi.
ePoxi
My designs @Thingiverse - RepRap Argentina Users Group Wiki - #RepRap.AR en Freenode WebChat - Grupo RepRap Argentina @Facebook
June 02, 2014 12:15PM
DIsculpa, ahi arregle el texto, el problema es que si lo dejo apretado, queda haciendo beep beep beep...
June 02, 2014 12:21PM
hola manuel yo tambien tengo el full, pero no me dio ese problema segurisimo que esta inchando las bolas el pulsador y como dice epoxi genera un rebote, lo que yo haria seria desoldarlo limpiarlo bien con alcohol isop. y probar de vuelta, la otra seria cambiarlo, seguro que se consigue ese modelo, de no conseguirlo podes cablearte un pulsador aparte o se podria hacer un anti rebote con un par de componentes para ese pulsador......
June 02, 2014 12:35PM
Mmm, ahi estoy hablando con David de 3dinsumos que es el que me lo vendio, no me siento seguro de desoldarlo al encoder, y como seria lo del anti rebote ?
June 02, 2014 12:41PM
manuel19941
Mira podrias hacer esto:
June 02, 2014 01:05PM
Ya lo corregí! David me paso otro firm y anduvo de 10, gracias a todos !
June 02, 2014 01:27PM
me alegrooo.....
October 29, 2016 10:51PM
Hola chicos ,
Acabo de adquirir este LCD para una RUMBA y tengo exactamente el mismo problema que menciona Manuel19941. ¿Me podrían enviar por favor el firmware para echar a andar este LCD?
De antemano gracias smileys with beer
