Re: ====> MAXIMUS CORE XY <==== January 16, 2015 03:37PM |
Re: ====> MAXIMUS CORE XY <==== January 16, 2015 05:31PM |
Re: ====> MAXIMUS CORE XY <==== January 16, 2015 05:34PM |
Re: ====> MAXIMUS CORE XY <==== January 17, 2015 02:00PM |
Re: ====> MAXIMUS CORE XY <==== January 17, 2015 06:22PM |
Re: ====> MAXIMUS CORE XY <==== January 17, 2015 08:01PM |
karimkfoure
Está muy bueno tu proyecto!
Mi pequeño aporte:
Podrías reemplazar los ventiladores de los fan ducts para PLA por unos así puestos verticalmente en el carril:
Te comería menos espacio en el recorrido de X
Re: ====> MAXIMUS CORE XY <==== January 18, 2015 09:47AM |
Re: ====> MAXIMUS CORE XY <==== January 18, 2015 10:16AM |
Re: ====> MAXIMUS CORE XY <==== January 18, 2015 10:24AM |
Re: ====> MAXIMUS CORE XY <==== January 18, 2015 11:12AM |
Re: ====> MAXIMUS CORE XY <==== January 18, 2015 11:18AM |
Re: ====> MAXIMUS CORE XY <==== January 18, 2015 04:20PM |
Re: ====> MAXIMUS CORE XY <==== January 18, 2015 04:34PM |
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 10:14AM |
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 11:15AM |
aleiovanevcp
Hola a todos, necesitaría que alguien que tenga un LCD full y una fuente 12 vcc 30A me confirme un par de medidas que me hacen falta para ver si lo que tengo esta bien, paso unas fotitos:
necesito esto por si tengo que modificar el diseño, tengo algo de avances del proyecto seguramente el finde estare subiendo. gracias.
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 01:17PM |
tatubias
aleiovanevcp
Ale tengo todo eso, te paso las medidas cuando vuelva a casa o te mando con tomas todo asi lo tenes a mano
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 04:04PM |
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 05:12PM |
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 05:17PM |
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 05:26PM |
Re: ====> MAXIMUS CORE XY <==== January 23, 2015 05:33PM |
Re: ====> MAXIMUS CORE XY <==== January 24, 2015 06:16AM |
tatubias
Ale me quedo picando este tema en la cabeza hace rato, ya que hay lugar para mover los cabezales por fuera de la cama, dejar un lujar para que se limpien los cabezales antes de comenzar a imprimir. onda una camita con la goma espuma que se usa para limpiar los soladores.
ya que la caja seria cerrada seria mas comodo con algun codigo g antes de salir a imprimi cuando se llego a la temperatura deseada que se ubiquen los cabezales para ser limpiados, como cualquier impresora de chorro de tinta.
mira este video, es lo que estuviemos hablando varias veces. por un lado una cama para limpiar el cabezal (esta nome gusta pero si anda todo ok) yyyy tambien el tema de hacer conductor la punta del extrusor yc uando toca las arandelas delos costados cierra el circuito y ya sabes cual es la distancia ya que es conocido el ancho de la arandela y no le agregas mas apartitos asi metidos en la cabeza.
[www.youtube.com]
otra cosa es mover los motores todos a la parte de abajo y conetarlos con una varilla a las poleas. para bajar el peso en la parte superior.
Re: ====> MAXIMUS CORE XY <==== January 24, 2015 06:19AM |
Re: ====> MAXIMUS CORE XY <==== January 24, 2015 04:53PM |
Re: ====> MAXIMUS CORE XY <==== January 24, 2015 06:41PM |
Re: ====> MAXIMUS CORE XY <==== January 24, 2015 11:31PM |
Re: ====> MAXIMUS CORE XY <==== January 25, 2015 07:54AM |
Re: ====> MAXIMUS CORE XY <==== January 25, 2015 08:10AM |
Re: ====> MAXIMUS CORE XY <==== January 25, 2015 08:27AM |
Re: ====> MAXIMUS CORE XY <==== January 25, 2015 07:18PM |
