Re: ![]() ![]() February 13, 2015 02:04PM |
Re: ![]() ![]() February 13, 2015 03:11PM |
Re: ![]() ![]() February 14, 2015 04:51PM |
Re: ![]() ![]() February 15, 2015 07:39PM |
Re: ![]() ![]() February 15, 2015 07:44PM |
Re: ![]() ![]() February 16, 2015 01:56AM |
Re: ![]() ![]() February 16, 2015 12:57PM |
Re: ![]() ![]() February 16, 2015 11:52PM |
Re: ![]() ![]() February 17, 2015 12:11PM |
Re: ![]() ![]() February 17, 2015 12:43PM |
Re: ![]() ![]() February 18, 2015 11:06AM |
Re: ![]() ![]() February 18, 2015 12:03PM |
nic0laz
Ale, extrusion directa es para cagadas, para fila de 1.75 necesitas una relacion de 1:1.5 al menos, sino, tarde o temprano el motor pierde pasos.
Hacete una reduccion, por mas chica que sea es mejor que nada.
Ademas, usa una rueda dentada mk8, al tener menos diametro que la mk7 perdes menos torque.
Avisame si necesitas y te hago un par
Re: ![]() ![]() February 18, 2015 12:31PM |
Re: ![]() ![]() February 18, 2015 04:19PM |
Re: ![]() ![]() February 18, 2015 04:32PM |
Re: ![]() ![]() February 18, 2015 04:42PM |
Re: ![]() ![]() February 18, 2015 05:18PM |
Re: ![]() ![]() February 18, 2015 05:22PM |
Re: ![]() ![]() February 18, 2015 09:47PM |
aleiovanevcp
nico tenes razon leyendo la hoja de datos dice:
The DRV8825 is capable of driving up to 2.5 A of current from each output (with proper heat sinking, at 24 V and 25°C).
El DRV8825 es capaz de conducir hasta 2,5 A de corriente de cada salida (con disipación de calor adecuada , a 24 V y 25 ° C).
si es asi le bajo la temp de alguna forma, (celda peltier, o algo asi) y listo... + 24vcc y chau.
Re: ![]() ![]() February 19, 2015 10:28AM |
Re: ![]() ![]() February 19, 2015 10:32AM |
Re: ![]() ![]() February 19, 2015 11:50AM |
aleiovanevcp
Re: ![]() ![]() February 20, 2015 11:01AM |
Re: ![]() ![]() February 20, 2015 11:03AM |
Re: ![]() ![]() February 20, 2015 12:20PM |
Re: ![]() ![]() February 20, 2015 01:25PM |
Re: ![]() ![]() February 20, 2015 05:21PM |
Re: ![]() ![]() February 20, 2015 06:58PM |
Re: ![]() ![]() February 21, 2015 08:52AM |
Re: ![]() ![]() February 21, 2015 09:38AM |
