Re: Cyclone PCB Factory June 30, 2015 05:43PM |
Pchiok
Hola Tatubias, los bujes van marchando, ya casi.
Las tuercas de 8 mm es para las roscas? te mando varillas roscadas de 5/16 con sus tuercas. Si necesitas además tuercas de 8 mm, te consigo.
Muy bueno y prolijo como va quedando, felicitaciones!
Re: Cyclone PCB Factory June 30, 2015 05:45PM |
Re: Cyclone PCB Factory June 30, 2015 05:52PM |
Re: Cyclone PCB Factory July 01, 2015 09:30AM |
Re: Cyclone PCB Factory July 01, 2015 09:59AM |
ChArDoN
Alguien encontro algun paso a paso de como va armado, yo ya arme parte de la estructura, pero como tengo poco tiempo para ver como va todo me gustaria pegarle una ojeada a algun paso a paso asi evito renegar.
Re: Cyclone PCB Factory July 01, 2015 10:04AM |
Re: Cyclone PCB Factory July 01, 2015 10:05AM |
Re: Cyclone PCB Factory July 01, 2015 10:23AM |
Re: Cyclone PCB Factory July 01, 2015 11:36AM |
Re: Cyclone PCB Factory July 01, 2015 11:38AM |
Re: Cyclone PCB Factory July 01, 2015 11:42AM |
Re: Cyclone PCB Factory July 01, 2015 01:49PM |
Re: Cyclone PCB Factory July 01, 2015 06:48PM |
Re: Cyclone PCB Factory July 01, 2015 07:00PM |
Re: Cyclone PCB Factory July 01, 2015 07:34PM |
Re: Cyclone PCB Factory July 01, 2015 07:40PM |
Re: Cyclone PCB Factory July 01, 2015 07:45PM |
SinapTec
Mientras que no meta mucho ruido y te cuelgue el arduino, cualquier fuente te va a servir, solamente tenés que mover 3 motores.
Re: Cyclone PCB Factory July 01, 2015 08:30PM |
Re: Cyclone PCB Factory July 01, 2015 09:11PM |
Re: Cyclone PCB Factory July 01, 2015 09:43PM |
Re: Cyclone PCB Factory July 02, 2015 09:34AM |
Re: Cyclone PCB Factory July 02, 2015 11:00AM |
Re: Cyclone PCB Factory July 02, 2015 02:17PM |
Re: Cyclone PCB Factory July 03, 2015 04:58PM |
Re: Cyclone PCB Factory July 03, 2015 05:49PM |
Re: Cyclone PCB Factory July 03, 2015 06:13PM |
tatubias
zumergido
mira que el dremel 200 se consigue en ml. en easy tambien los vi
El diseño original viene con el soporte parte dremel 200 así que esta todo ok.
Cual es la diferencia técnica entre el 200 y el 3000
Re: Cyclone PCB Factory July 03, 2015 06:51PM |
Re: Cyclone PCB Factory July 03, 2015 07:30PM |
Re: Cyclone PCB Factory July 03, 2015 11:32PM |
Re: Cyclone PCB Factory July 04, 2015 08:19AM |
abauerenator
Hola mientras espero el hotend de bsas me puse a cargar grbl en el nano y conecte con [chilipeppr.com] y si se puede hacer auto-level con grbl por medio del pin probé también les cuento que es la mejor interfaz para grbl que he visto hasta el momento hasta permite importar directamente archivos .brd desde eagle.
