Solo gira en un solo sentido el eje Z ???? April 18, 2018 10:54PM |
const bool X_MIN_ENDSTOP_INVERTING = false; const bool Y_MIN_ENDSTOP_INVERTING = false; const bool Z_MIN_ENDSTOP_INVERTING = false; const bool X_MAX_ENDSTOP_INVERTING = false; const bool Y_MAX_ENDSTOP_INVERTING = false; const bool Z_MAX_ENDSTOP_INVERTING = false; const bool Z_MIN_PROBE_ENDSTOP_INVERTING = true; #define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // Para invertir los pasadores de habilitación Stepper (Active Low) use 0, Non Inverting (Active High) use 1 // :{0:'Low',1:'High'} #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define INVERT_X_DIR true //INVIERTE EL SENTIDO DEL EJE X SEGUNSEA O "false" O "true" #define INVERT_Y_DIR true //INVIERTE EL SENTIDO DEL EJE Y SEGUNSEA O "false" O "true" #define INVERT_Z_DIR false // For direct drive extruder v9 set to true, for geared extruder set to false. #define INVERT_E0_DIR true #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true
