Nesting parts using Slicer 0.7.2b
Posted by willworkforplastic
October 27, 2012 04:12AM
I am trying to figure out what the best way is to nest multiple parts into a print using slicer 0.7.2b, as I do not want to deviate from the recommended G-code generator for tantillus.
Anybody got any good methods for this or pointers?
I tried netfab but the free version does let you export multiple STL's into one STL, and I cannot find anything to aid me in slicer.
Re: Nesting parts using Slicer 0.7.2b
October 27, 2012 12:10PM
You can use a newer Slic3r and export the plate to stl instead of slicing it. Or use the plater in pronterface, though that one is less flexible.
October 27, 2012 12:17PM
Tinkercad can import and export STLs and is free.
October 27, 2012 03:37PM
I personally use Blender as it is my tool of choice but anything you can import and export STL files with should work. Pokey's suggestion will work as well as using the Plater bundled with pronterface.
