Attaching gears to 4mm shafts
Posted by goopyplastic
February 01, 2013 02:04PM
Since the 4mm shafts don't have flats like the 5mm shafts, do we need to modify them by putting a flat on them or will they work fine being round?
Re: Attaching gears to 4mm shafts
February 01, 2013 04:02PM
Flats always help to reduce the chance of slipping so they are always a good idea. Be sure to at least put a flat on the extruder motor.
February 02, 2013 03:24PM
Another option instead of filing a flat, is to add some superglue, that way you'll get much less of a tendency for the gear to slip on the shaft. I ended up having to do that after my screws eventually came loose.
February 06, 2013 08:58PM
I can confirm this, especially for the extruder. 90% of my initial troubles with Tantillus were due to slippage.
