Metric design - will it be possible to replace the 1/4" threaded rod with a 8mm one? June 05, 2012 07:52AM |
Re: Metric design - will it be possible to replace the 1/4" threaded rod with a 8mm one? June 05, 2012 08:57AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Metric design - will it be possible to replace the 1/4" threaded rod with a 8mm one? June 05, 2012 10:12AM |
Re: Metric design - will it be possible to replace the 1/4" threaded rod with a 8mm one? June 05, 2012 03:45PM |
