Tantillus tubing?
Posted by thainfamousnate
Tantillus tubing?
May 17, 2013 03:57PM
im trying to find 3.1 mm I,D, Ptfe tubing called out here -
[reprap.org]
, but tantillus.org redirects me to the rep rap wiki page, has the store front disbanded?
i see 4 mm ID Tubing on ebay cheap from hong kong, but i worry about the play of 3mm filament in 4 mm tubing
Re: Tantillus tubing?
May 17, 2013 04:05PM
I recently became a Dad and moved so the store is down temporarily. The tubing I use is called 1/4" x 1/8" and can be found through Google fairly easily.
This is one of the things I know I have a lot in stock so if you PM me I could sell you some.
May 20, 2013 03:50AM
I'm using a 4mm ptfe tube with some 3mm pla, seems to be working fine.
