Missed the Indiegogo campaign, any chance I can still get a kit?
Posted by Eric Young
June 20, 2012 03:31PM
I'm new to the RepRap community and after looking into the various machines out there I'd really like to get my mitts on a Tantillus. Is there any chance I can still order the full kit from you? Or I can order the OTS parts myself if just supplying the custom parts would be easier for you.
Thanks for the amazing work you've done! I'm just awestruck at the resolution you're achieving with your machine smiling smiley
If you want any help making the version with the larger build area I'd be interested in putting in some time. I'm a ME and have been working in product development for 7 years doing mostly medical devices. I'm pretty handy with CAD and mechanical design in general.
Re: Missed the Indiegogo campaign, any chance I can still get a kit?
June 20, 2012 07:04PM
Thanks for the kind words.
I will be having a very short Indiegogo campaign for the Vancouver Maker Faire this coming weekend where you will be able to purchase one. After that I will be opening a webstore but not until all the Indiegogo campaign perks have been delivered and the instructions are complete.
June 20, 2012 08:38PM
Great, I'll keep an eye out. Thank you!
June 21, 2012 09:52PM
Would it be possible to make an 'other continent' kit with just the imperial parts in it?
Could save me some time trying to source it grinning smiley
June 21, 2012 10:07PM
Give me a list of what you think that would include and I will see about getting it set up.
June 22, 2012 06:23AM
I think this would be a nice set for something like this;
2 - 5/16" x 220mm Drill rods
2 - 5/16" x 197mm Drill rods
1 - 5/16" x 22mm Drill rod
1 - 1/4" x 180mm Threaded rod
4 - 1/4" Hex nuts
4 - 5/16" Hex nuts
3 - 1/4" Flat washers
The rest seems metric? I'm not sure what you mean with ' 10-32 hex nuts ' but I assume its M10?
June 22, 2012 07:01AM
> like this;
> 4 - 1/4" Hex nuts
> 4 - 5/16" Hex nuts
No, #10 UTF threads [en.wikipedia.org]
Honestly the only thing that is Metric right now are the 8mm rods, LM8uu / LM8suu and the M3's for the motors. And odds are the 8mm rods I am supplying are of higher tolerance then those available in most places (7.99mm).
June 22, 2012 07:02AM
The 5 day Maker Faire campaign is now live at [www.indiegogo.com]
Edited 1 time(s). Last edit at 06/22/2012 01:13PM by Sublime.
June 22, 2012 09:55AM
Cool .. and not so cool
You are using _3_ different standard for your material confused smiley
nobody in the world (beside those two small countries where you are from) can build this .. ffs
June 22, 2012 11:49AM
He's only using 2 standards, the #10/ #8 etc are the way small threads (< 1/4 inch) are designated for imperial threads etc.
Unless you are damn lucky, it's difficult to locally source metric parts in the US and locally they are usually dramatically more expensive than their imperial equivalents.
If you're ordering something online, it's a lot easier and the prices are closer to parity, but when you're designing something, it requires a degree of fore thought or a large enough collection of metric hardware that at least I lack.
The reverse is likely true outside the US..
June 22, 2012 11:58AM
Which is why (almost) the entire world now uses metric ..
June 22, 2012 12:02PM
I don't think so. I don't think you can get imperial at all in most countries unless you import from the US.
In the UK we can get BA and Whitworth from specialists, but I don't think that is the same as the US imperial system.
Edited 1 time(s). Last edit at 06/22/2012 12:05PM by nophead.
June 22, 2012 12:47PM
> metric ..
Sure, I'm English I jast happen to live in the US, I hate the Imperial system as much as the next guy, I don't think you'll find even many Americans defending it, but there are certain realities when you're trying to build something and want to be able to source hardware locally. Which is likely why Sublime chose the hardware he did.
For point of reference I can't buy any metric hardware under 5mm locally and even then the set of sizes is extremely limited (I can't buy metric jam nuts at all) and extremely expensive.
June 22, 2012 12:57PM
> ffs
Like Polygonhell said it is only two standards (Metric and Imperial UTS).
And small country? Canada is the second largest country on earth only second to Russia.
But yeah if I had designed it to use metric each kit would cost about double what it does now. I would have to special order all nuts and bolts. Worst part is we use the metric system in Canada but our hardware suppliers are all U.S. companies so we only sell Imperial hardware. With that said most of the nuts and bolts should be replaceable with an equivalent metric bolt and nut.
Edit: So little sleep = so many typos
Edited 3 time(s). Last edit at 06/22/2012 01:16PM by Sublime.
How easily will it be to extend the Tantillus (ie. larger print area)?
Would it just require longer rods and wires?
PS. I'm a complete noob when it comes to 3D printing. If I get one, it will be my first.
June 22, 2012 11:30PM
> larger print area)?
More or less yes.
The case needs to be wider and the rods need to be longer.
June 23, 2012 12:52PM
I'm just printing all the parts and gonna hunt for metals afterwards.
There are some parts that really should imperial right? Like the rods that are held with 608 bearings ...
Could you tell me which they are / provide that kit i talked about earlier? tongue sticking out smiley
buZz
June 23, 2012 11:39PM
buZztiaan Wrote:
> be replaceable
> metals afterwards.
> bearings ...
> buZz
The 8mm rods that Nophead has are small enough to fit through the 608's. The 8mm I am using is really precise (8mm +/- 0.013) and will not fit through.
So maybe take a pair of calipers or a bearing with you and see if they will fit.
Also my 5/16" measure 7.92 +/- 0.013
> like this;
> 2 - 5/16" x 220mm Drill rods See if the 8mm in your area fit the 608 bearings
> 2 - 5/16" x 197mm Drill rods See if the 8mm in your area fit the 608 bearings
> 1 - 5/16" x 22mm Drill rod See if the 8mm in your area fit the 608 bearings
> 1 - 1/4" x 180mm Threaded rod This is the Z lead screw and it will only require one part to be remodelled. If you can provide me a technical drawing of a 6mm nut I will remodel it.
> 4 - 1/4" Hex nuts Don't need them if we convert the lead screw to 6mm
> 4 - 5/16" Hex nuts Two of these are for the hobbed bolt which you can make out of a 8mm bolt and the other two have the threads drilled out to fit in the upper gears and have set screws threaded into them from the sides. If you can provide a technical drawing of a 8mm nut I can remodel it too.
> 3 - 1/4" Flat washers these actually have an 8mm hole so you can use any washer with an 8mm hole.
June 24, 2012 11:41AM
> remodel it too.
Would this help? [www.metrication.com]
I think i can get 8mm rods with different tolerances, so should be able to find some that fit 608 bearings smiling smiley
June 24, 2012 11:42AM
As I still have a spare hyena (the hobbed bolt from shop.arcol.hu) , could I use that as hobbed bolt for tantillus?
June 24, 2012 08:32PM
I've been following this for quite a while and I'm glad I've got another chance to build a Tantillus without major parts scrounging. A few questions first:
-I'm planning to get the print-everything-yourself kit, and I see little mention anywhere about the upper and lower bed. Those should be easy enough to cut and drill by hand, right?
-Is there any reason a Sanguinololu wouldn't work instead of RAMPS?
-I have finished printing three of the base pieces (base_1 to base_3) and I'm getting about 1mm of warp at the ends and in the corner. Will this screw things up when assembled if the rest of the pieces come out with similar warp?
Thanks
June 24, 2012 11:45PM
buZztiaan Wrote:
> Would this help?
> ml
Thanks I will have a look over the next week or so. We just had a our local maker faire this weekend and i have a trip to take this week as well.
June 24, 2012 11:48PM
> bolt for tantillus?
No it is not long enough. I have a couple of mini 8mm id ones that I do plan to modify the extruder to fit at some point.
The hobbed bolt needs to be 4-1/4" (110mm).
June 24, 2012 11:52PM
> first:
Yes the svg images are available in the laser cut folder of the github repo. Just print them out and glue them to a piece of wood and cut around them.
> instead of RAMPS?
The laser cut case has mounting holes for both RAMPS and Sanguinololu but the Sanguinololu does not have enough memory to run Marlin with the LCD and SD. You can replace the 644 with a 1280(1284?). Have a look at the Emaker huxley repo for the info needed to use the 128 in the Sanguinololu
The base no. The upper four do need to be really good as the bearings mount inside the corners and you want it square.
> Thanks
June 25, 2012 11:17AM
Do you have a technical drawing for this?
Arcol is willing to do custom work winking smiley
June 25, 2012 01:24PM
Sublime Wrote:
> pieces
> the
> you want it square.
I managed to get base_4 to print perfectly flat last night on heated blue tape and slic3r's new brim feature. Not sure if it was moving from hot kapton to hot blue tape or the brim that did it, but I'll experiment when printing the middle pieces.
One more question:
Is the hobbed bolt or the carriage middle piece included in the hardware kit, or do I need to go for that separate perk?
June 25, 2012 01:49PM
Give me a couple of days and I will try and get a proper one made up. Right now I just install the bolts in an extruder and use a felt pen to mark exactly where the filament hole is.
June 25, 2012 01:50PM
The hobbed bolt is included and I think I will include the extruder groove mount plate too for everyone.
