Re: Yonder's Tantillus Build
September 04, 2012 02:16AM
Sublime Wrote:
> The XYends are easier to print now. They no longer
> use zip ties to hold in the bushing. They are a
> little longer in one direction (still fit the
> printed case and does not lower any clearances).
> The nut traps opening is now from the end so the
> perimeters are continuous which makes them much
> stronger.
Thank you! I just broke yet another end trying to tighten and square the XY.
September 04, 2012 02:29AM
pokey9000 Wrote:
> longer
> clearances).
> the
> > stronger.
I have not uploaded them to Git yet. Would you like to test them? Email me and I will send you the file so you can test them.
September 04, 2012 02:02PM
> > Well, Eric Young has designed a mount for it
> > already. He is just waiting on my relocation
> > cable so he can mount it. Maybe he will release
> it
> > soon so others can try?
> That would be great. I hope he does share it...
> it looks like a perfect solution! Incidentally,
> if anyone doesn't want to wait for you to supply
> them with a relocation cable, they could do what I
> did and bundle up eight one-pin male-to-female
> jump wires. The reader works great for me...
> it's just not yet in the optimal position.
Here you go Yonder. I was going to wait till I had my Tantillus back up and running so I could print the parts and test them to make sure all is kosher, but if you (or anyone else) wants to give it a shot first the files are attached. I was also thinking of changing the LCD cover so it's mounted in between the LCD PCB and the acrylic, but haven't done it yet and don't know that I'll get to it soon.
open | download - LCD cover.STL (185.7 KB)
open | download - SD Card Reader Holder.STL (103.1 KB)
September 04, 2012 04:02PM
That looks great, guys.
Sublime, I know that GeraldO is talking to you about doing some Tantillus printing for you, and he said that he was gonna try reprinting the new XY ends to test for you. I'll gladly mount them onto my machine to try them out.
Also Eric, thanks muchly for sharing your great looking design. If I can resurrect my dead hotend tonight I may try printing that next to see how it goes. Cheers!
