It's Alive! ...sort of
August 16, 2012 06:56AM
Just working through getting the firmware installed... but construction is complete ...I think.
I've got the computer to recognize the arduino board but it won't upload the Marlin Firmware. I keep getting this compile error:
core.a(main.cpp.o): In function `main':
C:\Documents and Settings\lmulzet\Desktop\3DPrintSoftware-Tantillus\arduino-0023\hardware\arduino\cores\arduino/main.cpp:7: undefined reference to `setup'
C:\Documents and Settings\lmulzet\Desktop\3DPrintSoftware-Tantillus\arduino-0023\hardware\arduino\cores\arduino/main.cpp:10: undefined reference to `loop'
Edited 1 time(s). Last edit at 08/16/2012 06:59AM by Lisa M.
open | download - alive.JPG (510.7 KB)
Re: It's Alive! ...sort of
August 16, 2012 11:48AM
Nice build!
It sounds like you haven't selected the right project file in the IDE. You should have loaded the file "Marlin.pde" in the Marlin subdirectory. That should open a bunch of tabs, the leftmost one being "Marlin". From there, select Tools->Board->Arduino Mega 2560, then click the build button. It should churn for a minute or so and then say "Done compiling" on the status line. Then choose the right COM port in Tools->Serial Port and click upload.
August 16, 2012 08:00PM
Kewl thank Pokey. Now my LCD on the tantillus says 029/000 Tantillus 000%
...which definitely looks like something it should say.
I'm hoping I can figure out how to complete the setup tonight.
August 16, 2012 11:14PM
Hmm... I was trying to line up the bed ...when I realized something is wrong with this picture. I can't get the upper bed close enough to the hot end. It won't go any higher.
Is the endstop bracket to big?
Is the z-axis top too thick?
Are the holes in the case that the z-axis assembly mounts to in the wrong place?
Is it something else?
I can't figure it out.
My assembly of the z-axis matches the one pictured on Sublime's site from what I can see.
So glad we are having the build day. Looks like I'll have to put this project on hold until I can get some "in person" help.
Edited 1 time(s). Last edit at 08/16/2012 11:15PM by Lisa M.
open | download - uhoh-sm.jpg (241.8 KB)
August 17, 2012 12:39AM
What if I added more glass plates to the bed. I have two more ...and a bigger clip to clamp them to the bed. Can anyone forsee a danger with that idea? That would get the print surface closer to the hot end ...but also reduce print distance on the z axis.
August 17, 2012 11:23AM
I finished putting together my Z axis last night, and there doesn't seem to be as much room for adjustment with the #8-32 x 1" bolts as the pictures on the build guide show. Mine looks a lot like yours: with the plates separated as far as they will go, there's only a few mm between the inner nuts. I'll let Sublime chime in, but I suspect that we'll need a longer bolt for the bed corners.
Perhaps 1" bolts were fine before the design switched to using the shorter J-Head MkV.
August 17, 2012 11:54AM
You guys are both correct and someone else emailed me about it last night. I had all the #8 x 1" bolts as #8 x 1-1/4" at first and found them too long for the fans and to hold the extruder on so I changed them to the #8 x 1" which worked fine with the J-head mk-4b and then I upgraded all the machines to mk-5b which are shorter. I had tested the mk-5b but it was on a machine that had the original 1-1/4" bolts. This does mean that the bolts you have are a little to short to raise the bed up enough. I will be sending everyone the missing bolts along with the missing allen keys. But that will not happen until next week when I am back (7000 miles form home right now). For those of you in a hurry you could get some #8 x 1-1/4" bolts from the local hardware store (does not need to be allen head) and replace them with the ones I send you. I apologize for the mistake.
August 17, 2012 12:05PM
Sweet. I'm glad it is that simple. Phew. I wondered about the bolts too. I'm eager so I'll see if I can find them.
August 17, 2012 04:54PM
Are you going to send an email asking each person before shipping them? I don't need them fyi.
August 17, 2012 06:36PM
Yeeehaa!
Lisa - it looks like you and I are both on TEAM SILVER!!! (go team!)
I just finished my build - although I've yet to heat shrink my heat shrinks - any creative ideas on alternatives when I don't have a hair dryer or heat gun?
- and I'm going to go out and grab those longer bed bolts as well. - So I also won't need you to send me anything Brad.
I'd also like to say that you certainly put the RAD in Brad, Brad. Really impressive seeing the thinking that went into this while assembling. And also thanks for including the little things like the tape, and the mysterious extra nuts and washers
Once again, Yeeehaa!!
open | download - Tantillus_fresh.jpg (73 KB)
August 17, 2012 07:32PM
I went to Canadian Tire and Home Depot but they don't have the bolts. If anyone finds them, please let me know. I'd love to finish this. I'm going to a local build day on Aug 30 so I'll probably get my bolts then if I can't find them sooner.
I've heard Pacific Fasteners in Burnaby might carry them but I won't have time until later next week to go check them out.
I agree with you ernchesto. It was an amazing process assembling this and realizing that a person actually thought up how all this goes together and designed it. It has been a great experience. spinning smiley sticking its tongue out
August 18, 2012 04:10AM
> sooner.
I can put some in the mail tomorrow, but being in San Diego I don't know that it's worth the wait.
The name of the screw, if you want to call around to your local fastener/hardware stores, is a ' #8-32 by 1.25 inch long socket head cap screw'. Instead of socket head cap screws you can also use pan head, button head, round head, fillister head... pretty much any screw with a flat bottomed head. As long as it's #8-32 by 1.25 inch long then you're fine. I'd imagine a 1.5 inch length would be okay too, if the 1.25 is difficult to find for some reason.
I'm right there with the two of you, it's been a lot of fun doing this build and the thoughtfulness behind the design really shines as it's put together.
August 18, 2012 08:47AM
Hey Lisa, you can get #8 machine screws from home depot and Canadian tire in the bubble packs on the wall that say any package 1.99 . Home depot also says they have 8-32 x 1-1/2 [www.homedepot.ca] and individual [www.homedepot.ca]
Thank you everyone for your compliments, I have tried my hardest to put myself in your shoes to make assembly as easy as possible. I obviously dropped the ball on these bolts and the missing Allen keys but if that's the extent of the problems I am very happy. I would to thank everyone assembling Tantillus's right now for the feed back and help to improve what I already have done.
August 18, 2012 02:36PM
I was wrong about those different head types of screws being okay to use on the bed - the glass plate is sized specifically to fit between Socket Head Cap Screws from the looks of it. My apologies for the incorrect assumption.
August 18, 2012 07:44PM
@Sublime
Home depot, nearest my house did not have them. The smallest they carried was 10-32
I'll wait for the build day.
I'm worried about the electronics in my build. I think the power connector is faulty or not connected properly. The motors and fans and heater worked once briefly. Prior to that I could only connect to the board and the LCD had a very limited display. When the fans, motors, and heater stopped working, I could no longer connect to the tantillus at all with Pronterface. I got gobbledygook in the right hand panel after a longer than normal attempt to connect. Rather than make anything worse I've decided to wait for Aug 30
List of parts needed
Allen Keys
8-32 1.25 bed bolts
Fan mounts
Xy ends
I also cracked the original glass plate. It was too snug between the bolt heads on the top bed in the X dimension.I went to a glass place and they mad me two more ...but the glass somehow isnt quite as thick as the original.
I'm worried the power issue has done something to the board. I don't know if you have spares power connectors or boards but if you do can you bring to build day? I'll pay for them if it's through my impatience or lack of knowledge that they may be damaged/fried.
August 18, 2012 08:19PM
I just returned from the Home Depot on Terminal and they didn't have the allen-head units. I grabbed a pack of socket head ones that I'll file down and see how it goes. I don't think I'll be able to get the glass-locating capabilities of the cap-screws, however.
Brad, if you have a load of these, I'll retract my previous comment saying that I wouldn't need them. I'd like 4 if you wouldn't mind. I may be able to make the 22nd meeting, and could grab them then.
Thanks!
August 18, 2012 10:46PM
August 18, 2012 10:47PM
> Allen Keys
> 8-32 1.25 bed bolts
> Fan mounts
> Xy ends
> be damaged/fried.
No worries we will get it all fixed up for you.
August 18, 2012 10:59PM
Sublime Wrote:
> No problem. I may or may not make it back for the
> meeting on Wednesday.
Excellent. No big rush - I set it up with the 1.25" bolts - but questions have arisen!!
I'm still ~10mm off the bed when I bring it up as high as it will go. I moved the endstop up as high as I could without giving its' wires a hard time, but the motor refuses to push the bed up high enough to engage the switch. The motor shaft and the threaded rod are basically butted up against one another. (see attached image)
I'm still getting this terrible sound out of the motors when I do a move >1. The X is extra nasty where I can feel the motor trying to turn, but it's like it's created its own friction and working against itself. I just unplugged it when it seemed to freeze in position. I know that this is kinda mixing up threads on here because I mentioned this and learned of the pots as being a potential source of this... Not really sure what I can 'safely' do to configure...
All thoughts are ultra-welcome.
open | download - Zheight.jpg (74 KB)
August 18, 2012 11:39PM
ernchesto Wrote:
> the
This is strange indeed. In this picture you will see the z-lift is off to the right side. This is where it wanted to be, not because I put it there on purpose. The bracket should float from side to side to allow the lead screw to self center. It also allows the sides to move in and out enough that they do not constrain the linear bearings.
See the other thread.
August 19, 2012 12:07AM
Sublime Wrote:
> ernchesto Wrote:
> > the
> as
> high
> time,
> and
> against
I've managed to get the bed ~5mm from the extruder tip (by homing the Z - strange that it was able to travel further than I was able to nudge it. I'll keep the rod alignment in mind when I troubleshoot.
> the
> nasty
> when
> this
> a
> I
Done, thanks!
