Pronterface says Motors are Off August 17, 2012 11:01AM |
Re: Pronterface says Motors are Off August 17, 2012 11:55AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Pronterface says Motors are Off August 17, 2012 12:11PM |
Re: Pronterface says Motors are Off August 17, 2012 12:32PM |
Re: Pronterface says Motors are Off August 17, 2012 01:06PM |
Re: Pronterface says Motors are Off August 17, 2012 07:40PM |
Re: Pronterface says Motors are Off August 17, 2012 10:26PM |
Re: Pronterface says Motors are Off August 17, 2012 10:32PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Pronterface says Motors are Off August 17, 2012 10:41PM |
Re: Pronterface says Motors are Off August 17, 2012 10:46PM |
Re: Pronterface says Motors are Off August 17, 2012 11:52PM |
Re: Pronterface says Motors are Off August 18, 2012 01:19AM |
Re: Pronterface says Motors are Off August 18, 2012 08:28AM |
Re: Pronterface says Motors are Off August 18, 2012 11:04AM |
Re: Pronterface says Motors are Off August 18, 2012 05:41PM |
Re: Pronterface says Motors are Off August 18, 2012 11:33PM |
Re: Pronterface says Motors are Off August 19, 2012 12:03AM |
Re: Pronterface says Motors are Off January 16, 2016 12:22PM |
Sublime
By the sounds of the other thread the problem was the power connector and the baud rate so I will not add any info now to confuse you. As for what Lem said about home being in the back corner, I did this so when it returns to 0, 0 after printing and you reach into the machine to get the part out that you do not have to reach past the 200c hotend and burn yourself.
