Heated Print Bed and Issues November 12, 2012 09:45AM |
Re: Heated Print Bed and Issues November 12, 2012 04:15PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Heated Print Bed and Issues November 13, 2012 10:46AM |
Yes, it takes 4 min 30 seconds to reach 110c. This is a surface calibrated temperature. It would seem that it could maintain 110c with no time limit, it is running about 70% on time which should give ramps and the wires time to cool down. I ran it all the way up to 125c just to test and held just fine, but it getting close to 100% on time.Quote
Sublime
Have you seen if it will reach 110c for ABS?
Sublime
Are you running two power supplies?
