Roboteernat Wrote:
> Hi,
> I seems to be having difficulty slicing a few
> parts,
> Z_arm_2 is the one im having issues with atm, is
> there an issue with the stl file? i cannot seem to
> fix it in netfabb nor admesh
> is anyone else able to slice it?
> Thanks
> Nat
I have had an issue where one of the arms has the infill escape the perimeter in the two large holes while slicing with Slic3r 0.7.2b. To work around it you just need to rotate the model a few degrees. If this does not work for you you could mirror the other arm that slices properly using your favorite modelling program. Hope this helps if not just let me know and I will see if I can fix it.
P.s. only one side was modelled and then I mirrored it using Blender. Then they were both most likely repaired and the mirroring before repairing may be what caused the issue.
