Laminate Issues Nothing Sticks November 26, 2012 04:28PM |
Re: Laminate Issues Nothing Sticks November 26, 2012 05:32PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Laminate Issues Nothing Sticks November 27, 2012 09:11AM |
Sublime
Glad to here you built a second one.
Yes, I am running KISSlicer. I am running the true 5D measuring the extruded distance on both machines. Watching the fill it seems correct.Quote
Sublime
My first thoughts are did you calibrate the E steps the same way as with your first one? If the flow is too low you do not get much pressure between layers so it does not stick well.
Yes, It actually extrudes smoother than any of my other nozzles. It doesn't curl as it exits and just a perfect smooth line. I also did the pull the plug method at a low temperature. When I pull the end, It is clean and a perfect shape of the nozzle internal. In the past when I have something blocking it, I can see the plug is not a perfect cone, and the tip doesn't have the point going into the nozzle end.Quote
Sublime
Second thought is have you checked if the filament comes out nice and smooth when you extrude into air? The nozzle may be clogged which reduces the extrusion rate and could cause the hobbed bolt to slip.
I ran a small test last night and it seems to print just fine...Quote
Sublime
Third is have you tried the filament back in the first machine. It may be possible the first half of the roll was good and it went to crap right when you switched machines.
Re: Laminate Issues Nothing Sticks November 27, 2012 06:29PM |
Re: Laminate Issues Nothing Sticks November 27, 2012 08:46PM |
Re: Laminate Issues Nothing Sticks December 06, 2012 01:16PM |
