Tantillus Plus files?
Posted by goopyplastic
January 10, 2013 12:01PM
Are these out in the public somewhere?
Re: Tantillus Plus files?
January 10, 2013 06:42PM
I don't have any files for the plus. Two other people are working on them and when they see this they may post what they have so far. I actually had a drive fail a month ago and lost everything new I had been working on. I lost the new firmware, machine upgrades, slicing profile, etc.
January 15, 2013 11:17PM
I have some models made up for a 100mm x 200mm x 100mm build area Tantillus if you want them. They are based on some of the the old Metric Tantillus models from WWFP and may have some minor dimensional issues that have since arisen. I should fix them up anyways though, so if you want to build it I can take the time to fix them up and send them your way. I don't know who else is working on a bigger version, but their files might be better than what I have.
January 16, 2013 07:38AM
That would be me... smileys with beer
I'm working on a 150 x 150 x 200 version. It's currently on hold while we get the laser cutter installed and setup so that we can cut the acrylic. Once I have the panels assembled and make sure there are no major problems, then I'll share the files.
Lem Fugitt
3D Printing Dreams
Robots Dreams
"The map is not the territory."
January 17, 2013 01:23PM
yay! looking forward to it.
February 18, 2013 02:58PM
> might
> the files.
Have you made any progress? Are you in a position to release the files?
thanks,
Brendin
February 19, 2013 07:35AM
Still waiting on the laser cutter installation/setup to cut the panels.
Lem Fugitt
3D Printing Dreams
Robots Dreams
April 14, 2013 05:16PM
I Have files (corel) for 3mm dibond version with 150x200x150 table. I've redesigned extruder(it have now 1:9 ratio) Z upper and lower rods holders and corners and many files nothing left orginal, soon I will give it public ehen i'm test it. But I can now give the sides drawings
