Re: New Slic3r February 03, 2013 09:42PM |
Re: New Slic3r February 03, 2013 10:06PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: New Slic3r February 03, 2013 10:29PM |
Re: New Slic3r February 04, 2013 04:35AM |
nophead
> I have never understood why slic3r doesn't simply
> do what its name implies. I.e. slice the object
> you give it and use that as the outline for each
> layer (offset by the filament width of course).
Re: New Slic3r February 04, 2013 05:02AM |
Sublime
> I will not be spending the time to test Slic3r
> 0.9.8 after these renderings made with Repetier
> host were posted in the Slic3r thread showing that
> Slic3r 0.9.8 can not slice a simple shape (cube
> with one rounded corner) and produce smooth sides.
> This is all the proof I need to say that after
> Slic3r 0.7.2b Slic3r fails at consistently slicing
> things accurately. This eliminates all the
> possibility that the issues are caused by hardware
> and show it is at the time of slicing the problems
> are created. No more need to discuss it.
Re: New Slic3r February 04, 2013 10:29AM |
Admin Registered: 17 years ago Posts: 7,881 |
That's what Slic3r does - except it offsets the outlines by half the extrusion width, but I'm sure you know that.
Re: New Slic3r February 04, 2013 11:31AM |
> What about mitre limits, different hole sizes and
> all the spiky artefacts people keep reporting?
Re: New Slic3r February 04, 2013 01:22PM |
Re: New Slic3r February 04, 2013 03:33PM |
Re: New Slic3r February 04, 2013 05:47PM |
Re: New Slic3r February 05, 2013 05:58AM |
richrap
> Hi Alessandro - I did spot some odd spikes while
> doing some tiny printing last week, this was with
> the 0.9.8 release, I hope they are just Repetier
> rendering errors.
Re: New Slic3r February 05, 2013 06:34AM |
Re: New Slic3r February 06, 2013 07:06AM |
