X Y resolution - 8 micron details
Posted by Sublime
January 31, 2013 02:26AM
I decided to do some tests to see what Tantillus's actual X Y resolution. To do so I made a 20 x 20 x 10mm cube and embossed number into the side of it. 8, 16, 32 and 64 each number is inset into the surface by its value in microns. So 8 microns for the 8 and 16 microns for the 16 and so on. I chose 8, 16, 32, 64 because they are Tantillus's theoretical resolution at 16x 8x 4x 2x microstepping so I figured they would be a good bench mark of whether microstepping actually gives higher positional accuracy.
STL 8.16.32.64-test.stl
I then sliced it with Kisslicer 1.1.0 pre-beta with a single wall 0.5mm wide and 150micron layers at 45mm/s with a minimum layer time of 0 seconds to prevent it from slowing down. No retraction.
Gcode 8.16.32.64-test.gcode 0.5mm nozzle, 3mm filament
This is the second oldest Tantillus and it still has all of its original gears and printed bushings. It even has printed bushings on Z. If you listen to the video you will hear that the gears make a little noise because they have worn a little and have a very small amount of backlash. Clearly this is less than the depth of all the imprints as you will see.
I was amazed to see that all of the depths are visible and legible. Although at these depths faint.
To be clear these are 0.008mm 0.016mm 0.032mm and 0.064mm deep embossing's on a 20mm block.
VDX
Re: X Y resolution - 8 micron details
January 31, 2013 02:53AM
... can you see a difference between 0.008 and 0.016?
It seems the difference from 0 to 0.008 is a visible difference (mybe more by slowdown at the edges than inset?), and from 0.032 to 0.064 too ... but not between the smalles steps confused smiley
Viktor
January 31, 2013 02:59AM
> 0.016?
You can feel them all and they are all inset into the face. I tried to caliper them but they are not precise enough to measure the difference since you can effect it that much just by pushing a little. I will try and take some pictures under the microscope and post them soon.
January 31, 2013 03:14AM
OK microscope photos.
8 Micron detail (outside)
16 Micron detail (outside)
16 Micron detail (inside)
Edited 1 time(s). Last edit at 01/31/2013 03:15AM by Sublime.
January 31, 2013 03:19AM
Holy shit that's cool, I've never attempted to emboss my prints by such a small distance but it's awesome to see the level of detail one can expect. I would have expected the edges to blur but they are fairly defined for such a small inset.
Gorgeous and consistent layers btw, excellent printer.
February 03, 2013 03:45AM
I had a go at Richraps challenge to print Emmets secret heart box at 50% scale in the tiny printing competition. Be sure to check it out. [forums.reprap.org] Richrap has printed lots of tiny stuff on his Tantillus and others have printed some really really tiny stuff on other printers too.
February 09, 2013 06:07AM
February 10, 2013 03:26AM
February 13, 2013 12:56PM
Awesome grinning smiley
February 14, 2013 05:43PM
Awesome indeed. Nice test!
March 01, 2015 04:40AM
How is Tantillus's theoretical resolution calculated?
I can't wrap my head around this... and could find other thread about this topicconfused smiley
March 03, 2015 08:45AM
Rexus
After some more thoughts, I think I got itsmiling smiley
Here is my calculation:
  • Tantillus use 5/16" rods to wrap the wires, it's circumference is:
    π × diameter = 3.14159265359 x 7.9375 = 24.9363916879 mm
  • Tantillus's motor produce 1.8° of turn for 1 step, 200 steps for 360°, 3200 steps for 360° after 16x microstepping.
  • Which means 1 single step move the X or Y axis 24.9363916879 / 3200 = 0.0077926224, which roughly equals to 8 microns.
Edited 1 time(s). Last edit at 03/03/2015 08:47AM by Rexus.
