Nico's Build
Posted by Nico3ck
Nico's Build
February 01, 2013 01:57PM
Hi all, I've started my tantillus build, taking pictures as I progress, I'll put them here later when I'm finished.
It's looking good so far, I'm still waiting some parts before putting everything's together.
I'm a bit stuck at the endstop soldering; I don't know which wire goes to which pole.
- S (yellow) should go to C
- gnd (black) NC or NO ?
- +5 (red) NC or NO ?
Could somebody help me on this one ?
I'm also a bit lost on some of the lcd panel wire :
black should be on vss (with brown & some sort of rotating switch), rw and k (with the second rotating switch)
a red wire is on this 2nd switch, should I solder back & this red on rw ?
orange is on rs, but one of the 1st switch's leg is already soldered there; should I unsolder it and put it back on with orange ?
Edited 1 time(s). Last edit at 02/01/2013 03:47PM by Nico3ck.
Re: Nico's Build
February 01, 2013 04:43PM
> when I'm finished.
Black and white go to the outer terminals of the switch (no polarity). The middle terminal and red wire are not used.
> rotating switch)
This is how it should look. I will try and get a better diagram up soon.
Note the colors may differ due to batch differences.
Let me know if you need more help.
Re: Nico's Build
February 01, 2013 05:36PM
My left rotating switch does not seems to be soldered as yours.
What I see on your .jpg, from the left, is :
1 - brown
2 - long red + left back leg
3 - front leg
4 - orange + short red
5 - right back leg
Is that right ? the rest seems ok.
Re: Nico's Build
February 01, 2013 06:11PM
> soldered as yours.
> 1 - brown
> 2 - long red + left back leg + wire to leg of second potentiometer
> 3 - center leg
> 4 - orange + short red just the orange
> 5 - right back leg + short jumper from 1 (brown) + jumper to 16 (brown)
Very close just 2 - 4 were a little off
Re: Nico's Build
February 01, 2013 07:39PM
Thanks, it's done.
It could be a bit nicer, but it will work !
I'll keep you updated.
Re: Nico's Build
March 05, 2013 11:09AM
Yesterday I finally finished building / preping my Tantillus; x, y & z are moving, extruder is extruding.
But (as everything can't be perfect) my lcd screen doesn't light up.
Is there something wrong with the way i've plugged it in ? if no I'll add some picture of the solered wires tonight.
edit
wiring :
The goo-like stuff is silicon; I put some because I feared the wires would touch, but now it seemed a bad idea ...
Edited 1 time(s). Last edit at 03/05/2013 07:16PM by Nico3ck.
Re: Nico's Build
March 05, 2013 11:07PM
I believe the brown and red wires need to be reversed on the ramps exp1 connector. You have brown (ground on the lcd) plugged into + on the ramps shield.
Re: Nico's Build
March 06, 2013 03:05PM
Nope, it isn't this.
I trided to switch the wires but the printer does not boot in this config (no lights)
Re: Nico's Build
March 06, 2013 04:52PM
Ok I think I found the problem. Have a look at the attached picture with my notes . I think you have an extra wire going to RW. Also the red and brown on the connector will need to be switched after correcting the above noted wire.
Re: Nico's Build
March 07, 2013 05:56PM
After some soldering, it's still the same.
Here is a picture of what it looks like:
From right to left :
1 - brown + black (goes to 5)
2 - red + red (goes to 2nd pot right leg) + 1st pot right leg
3 - 1st pot front leg
4 - orange
5- 1st pot left leg + black (goes to 1)
6 - yellow
7 -
8 -
9 -
10 -
11- green
12 - blue
13 - purple
14 - gray
15 - 2nd pot front leg
16 - 2nd pot left leg
Re: Nico's Build
March 07, 2013 07:00PM
> [img4.hostingpics.net]
> pot right leg
> 4 - orange
> 6 - yellow
> 7 -
> 8 -
> 9 -
> 10 -
> 11- green
> 12 - blue
> 13 - purple
> 14 - gray
That picture still shows a red wire going to pin 5 but your description does not have the red wire and I believe it is the issue.
Re: Nico's Build
March 08, 2013 03:52PM
I uploaded twice the same image ... This is why sleep is nedeed from time to time !
Re: Nico's Build
March 08, 2013 03:59PM
I probably should have asked you this first. Have you tried turning the pots? Start with the one on the left first and see if you can get the back light lit. Once it is lit up then turn the other one to set the contrast so you can read the display. Also some of the displays came with a little solder jumper soldered that needs to be unsoldered, its marked j3. If it was none of those can you check with a meter you are getting 5v and ground.
Edited 1 time(s). Last edit at 03/08/2013 04:13PM by Sublime.
Re: Nico's Build
March 08, 2013 04:23PM
I checked j3, there is no jumper betwin the 2 little bits of solder
Turning the pots des nothing.
Between 1 and 16, I mesured about 1v.
Without the lcd, the arduino lights up nicely, but with the lcd plugged in, no reaction (no lights, no sounds)
Re: Nico's Build
March 08, 2013 04:34PM
Ok that tells us you have a short between + and - . Is it possible one of the legs on the pots is bent so far it is touching the center tap of the pot? Can you test for continuity between solder points.
Re: Nico's Build
March 08, 2013 04:59PM
The pot's back legs don't touch the center leg.
Here is what I found between the solder points :
1 <> 2 : 0.94
2 <> 3 : 0.10
3 <> 4 : 0.6
4 <> 5 : 0.2
5 <> 6 : 0.2
6 <> 7 : 0.6
14 <> 15 : 0.1
Re: Nico's Build
March 08, 2013 05:39PM
Hmmm.. If those are readings from the meter set on resistance than the 1 <> 2 looks like the one with continuity which could be because it is still connected to the RAMPS board.
Can you unplug all the wires from the four pin connector that has the red/brown wires and try putting them in in this order Red, Brown, Orange, Yellow and try connecting it to the RAMPS and see if you get 5v and ground at the LCD. If you still do not get 5V we can rule out a short caused by the other wires. In the end it could be a bad LCD ( I have one that does not work out of 100 [the one I use for pictures]).
Re: Nico's Build
March 11, 2013 07:12PM
After scratching my head for a while, I re-checked every wires, and when I was re-reading the post I found that the first picture was not showing rightly the red & brown wire.
Just after the bend, they twist and the brown is plugged in what seems the red and vice-versa - theses wires don't need to be reversed.
So since the 7th we are trying to work on a something that can't work that way, the joys of tele-debugging ...
So after getting brown and red rigth, I do have something - the backlight seems to be working a bit, around 1/10th of [farm9.staticflickr.com] (even with max power from the pot).
There are some black pixel on the lcd, seemingly placed at random.
Re: Nico's Build
March 11, 2013 09:29PM
I do not know if they have any protection against reverse voltage so it may be damaged in some way. Or it may be that jumper J3 has a little solder on it still. Try running a utility knife between the pads while the power is off to be sure the circuit is broken. It enables a smart brightness feature that does not work correctly for some reason.
Re: Nico's Build
March 12, 2013 07:08PM
Well, no change after cleaning a bit more the 2 pads ... It seems my lcd is cooked.
Do you have some lcd left ?
If yes, I'd like to order another - if you could solder it and test it on your printer I'll gladdly pay for the extra.
For some good news, my Tantillus is up and running, some fine tuning is still going on (axis step by unit atm, there are still some small ridge forming due to an over-extrusion of pla).
Here are some videos of a gear bearing printing :
- begining : [www.youtube.com]
- hotend close-up : [www.youtube.com]
- longer HD middle print : [www.youtube.com]
Do you hear / see something that's wrong ?
Sadly It could not print to the end, pronterface froze at ~70%.
I'm now printing a support for my fans, edited to take them correctly.
I'll post some picture of the ongoing build later and my thoughts about it.
Re: Nico's Build
March 12, 2013 07:30PM
Yes just email me about the LCD.
If the video is actually how the machine sounds I think there is something wrong but I have no idea. Or the microphone was cutting in and out because of the volume of the machine. The sounds between when the sound cut in and out sounded fine. A little high pitch which could just be the motor current being a little off. Other than that it looks perfectly assembled. Looks like you spent some time to get the cables perfect.
Re: Nico's Build
March 12, 2013 08:43PM
The motors tends to "sing" when printing something round, this can be this noice you are talking about. As my X and Y slipped twice during calibration, I upped a little the current going to the motors.
While printing my fan mount, I noticed the gears are rattling a bit when going rapidly from side to side, in certain positions.
After my cables got loose (I over tightned them and they slepped on the axis) I tried to get them really right.
I found it easier to wrap them in a neat coil around the shaft from the start.
My main concern is now to perfectly tune the pla flow, to keep of the ridges & little blobs (next test : 348)
Re: Nico's Build
March 26, 2013 12:41PM
Here are a few picture taken during the build, and my comments
"Strucure" pieces, printed by by Ghun from the french forum
Cables, motors, bearings
Screws
Fans (I did not used theses ones but a larger one), gears, electronics
Encoder, lcd screen and cable kit
Starting j-head build
j-head done, ready to take fly
Work started on the hobbed bolt
Montage de la partie fixe de l'exrudeur
Ajusting ...
Structure nearly done
Creating a flat
Finishing the extruder's bolted part
Finishing the extruder's moving part
Working on Z
Working working working
A little csk to get clean drilled holes
Searching the perfect fit (did not work in the end
Since 2 of my rods were a bit bit large, I needed to use unusual tools for a 3D printer
Starts to looks good !
Working zone
First real print
After a few starting problems - the thread count on Z was off by minus 20% - everything is nicely tuned. I just printed the encoder knob on 0.1, quality is nice (at max speed)
Re: Nico's Build
March 26, 2013 01:47PM
Nice work documenting your build. I had the hardest time remembering to take pictures and I built a lot more than one.
Please keep us updated with results.
Re: Nico's Build
March 27, 2013 02:43AM
Nice! Was that the metric version or original version?
Re: Nico's Build
March 27, 2013 06:37AM
I used your metric files, in France finding imperial screws or rods is very difficult.
