Case Panel dimensions
Posted by logandr
March 27, 2013 08:42PM
Could someone tell me the dimensions of the laser cut case panels (actually, need the dimensions of one of them). I'm printing the case panels on paper and then using the paper to make the cuts by hand ( and band saw and drill press etc) and I want to be sure they scaled correctly. To the nearest mm would be great.
thanks
Re: Case Panel dimensions
March 27, 2013 10:50PM
Blender tells me they are 209mm x 300mm. Another way to check the scale would be the bearing holes need to fit 608 bearings in them.
