Shorter hobbed bolt
Posted by lajos
Shorter hobbed bolt
May 10, 2013 05:07PM
On my first attempt to print the extruder the printer ran out of filament at about 95% through. I obviously need to print a new one, but I was wondering if I could use a shorter hobbed bolt. I have the equipment to make the bolt.
Is there a design reason for such a long bolt, or would a shorter one work with a modified extruder body?
Re: Shorter hobbed bolt
May 10, 2013 05:17PM
The point was to get the motor and gear assembly down below the bed as it is too wide to fit beside the bed while keeping the exit hole for the filament up as high as I could to keep the bowden tube as short as possible and keep it a smooth curve form the exit all the way to the hotend.
May 10, 2013 05:55PM
Thanks for the insight. I had a suspicion that there was a reason for the long bolt.
