PLA for carriage top / bottom?
Posted by goopyplastic
May 12, 2013 03:14AM
Is PLA ok for the carriage top / bottom pieces or with the heat should they be printed in ABS?
Re: PLA for carriage top / bottom?
May 12, 2013 01:01PM
All of my machines and all the machines I have built since the Indiegogo campaign have been 100% PLA without any issues. Although if you plan to print materials that require higher temps then PLA you may want to use ABS for the carriage.
