Re: Variant of Goopyplastic's Tantillus Variant (Ingentis) May 26, 2014 02:05PM |
Re: Variant of Goopyplastic's Tantillus Variant (Ingentis) May 26, 2014 03:39PM |
madmike8
Would using a stepper worm gear arrangement to turn the Z shaft keep it from falling with the power off?
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Variant of Goopyplastic's Tantillus Variant (Ingentis) August 11, 2014 06:34AM |
Re: Variant of Goopyplastic's Tantillus Variant (Ingentis) August 14, 2014 02:47PM |
It might be that the effect of implementing such stuff is that the printing platform will slowly come down, the speed being actually established by design. I think the same story apply to the alternative way.
Re: Variant of Goopyplastic's Tantillus Variant (Ingentis) August 14, 2014 05:00PM |
. For keeping it still without power use a brake for the stepper, but if you keep the z-motor powered at all times the fact that the bed falls after shutting down the power is only a problem if it falls very fast and then crashes badly at the bottom (shock absorbers may be an easy fix for that too).
