Hotend Options
July 13, 2013 04:04AM
Hello,
I'm in the process of acquiring my first RepRap and have chosen Tantillus as the technical and aesthetic design appeals to me and the results you guys are getting look great. I've decided to go with the Imperial lasercut model as the frames and printed parts are available in the UK, where I am based.
The only parts I am having difficulty sourcing are the 1/4" - 20 threaded rod in SS and the J-Head Mk-VB Hotend. I know I should be able to get both from the USA or Canada, but I'd like to avoid import duty and high shipping charges by sourcing locally, if I can.
Is anyone aware of a UK/EUR source of the Mk-VB Hotend?
Is it essential to use the brass variant, as there are a few local sources of aluminium Mk-Vs?
Has anyone experience of other Hotends with the Tantillus?
For example, This one from E3D which appears to be compatible with the carriage.
Greg
Re: Hotend Options
July 13, 2013 09:43AM
I'm building a metric lasercut in the uk.
Printing the plastic on my mendel and lasercut the case from mdf myself.
Ben
Re: Hotend Options
July 13, 2013 01:51PM
The Aluminium hotend should work fine but be aware that knock off J-heads can be troublesome. If it is from a reputable seller you should be fine but be sure to do the research. The shipping of the J-head from hotends.com is really low and worth the extra time.
There is at least one machine with a Makergear hotend that looks to print well.
The E3D has been discussed for Tantillus (can't find the thread) but my concerns at the time were clearance of the fins on the carriage and X/Y ends.
Also it does not look like all metal hotends are doing as well as claimed. I am not saying anything against any particular model. Just that they seem to have issues with PLA and printing at slow speeds because the melt zone is so long and gradual without a definite transition zone.
Also it is possible to use a non-groove mount hotend with Tantillus by using the carriage bolts to hold the PEEK cross bar support on a lot of other hotends.
Also note that the J-head has some things that I believe help with a Bowden cable:
Long exit hole.
Medium length melt zone.
Short transition zone.
Re: Hotend Options
July 13, 2013 05:48PM
I will take your advice, the hotend is too risky to mess with, at least while I'm learning. I'll go with the original from the US. Its not as though I need one straight awaysmiling smiley
Makes sense to pass on the E3D for now as PLA is the prime filament. Would be nice to try nylon in the future perhaps, but that will be way up my learning curve. It looks like fan cooling is needed for PLA with all metal hotends. I think this would compromise the low moving mass offered by your design.
Thanks for your very detailed advice.
Time to start acquiring the parts...
Re: Hotend Options
July 13, 2013 06:05PM
> Ben
Unfortunately I don't have access to either for my first build or I'd probably of metric. The ones on the Emaker site are imperial, though I don't know if there are any significant differences, or whether metric prints work with imperial case. Did you find any issues printing the metric parts?
Re: Hotend Options
July 13, 2013 06:32PM
> the
> > Ben
WillWorkForPlastic did his best to make all the metric parts backwards compatible with the Imperial ones so the laser cut parts should be fine. Also the person selling the parts may be willing to cut and print the metric ones for you.
Re: Hotend Options
July 13, 2013 07:48PM
That will give me more flexibility if I can use metric vitamins/prints with an imperial case. I was reading an early thread where you said that you had used some metric nuts and bolts with the imperial printed parts and that the problem was aperture for captive nuts. I imagine that the metric version addresses these issues and optimises hole clearances for the metric hardware. I expect I may still need to use 5/16" silver steel for the rotating rods rather than 8 mm because of the 608 bearings.
I believe the case is cut, but I still have the option to go metric for the printed parts.
Thanks
Re: Hotend Options
July 19, 2013 12:43AM
Has anyone gone with a Chinese J-Head off eBay? I'd like to get mine from hotends.com but they are out of stock and I haven't found many other options.
Re: Hotend Options
July 19, 2013 03:25AM
> options.
Many people have, we can't recommend you do. There have been dozens of posts about jammings and worse.
If you want a J-Head you are not limited to just the designer who sells on hotends.com, somewhere he put together a list of other good quality producers, perhaps on RepRap wiki.
Re: Hotend Options
July 19, 2013 11:52AM
Here is Brian's post about J-head clones [jheadnozzle.blogspot.com]
It looks like the Makerfarm one was a lot better than the China eBay.
Funny thing is normally I say for the price savings you get when you buy from china go for it and take the chance of getting a dud, but not when it comes to the hotend.
Also Brian posts new hotends every Friday evening (Pacific time) and they sell out fast. So have a look tonight and you should be able to get one. Also you can put all the parts for one into a cart and buy it that way. Then send him a note saying you would like it assembled. There is a good chance that he will redo the price as a complete hotend or throw in something extra for paying more in parts.
Re: Hotend Options
July 24, 2013 02:41PM
> are
> > options.
> worse.
I've been testing the next generation of hot ends for my Tantillus, the Chess Piece [www.2engineers.com]
Edited 1 time(s). Last edit at 07/24/2013 02:42PM by Arc_Tesla.
Re: Hotend Options
July 25, 2013 01:20PM
this is a quick pick of my chess hot end drinking smiley
open | download - chess_hotend.jpg (48.8 KB)
