Bed too low
Posted by maik
Bed too low
August 02, 2013 03:38AM
So I finally got my build finished and went to start leveling the bed. I've pushed the endstop all the way up against the upper z bracket, told it to find Z home and there's still a good 1/2"between the bed and the tip of the nozzle.
Did I do something wrong? I'm assuming this can be fixed with longer bolts between the top and bottom, but I'm using the ones from the BOM.
Re: Bed too low
August 02, 2013 10:38AM
Are you by chance using a J-Head Mk V? I know it is a bit shorter than previous J-Heads.
Re: Bed too low
August 02, 2013 01:53PM
Yeah the instructions are for the J-head I supplied with the kits which was in between the length of a Mk4 and a Mk5 so the bed bolts may be too short for a stock Mk5.
Re: Bed too low
August 02, 2013 03:00PM
So would it be better to use a Mk4 like this one [www.makerfarm.com] if we are following the build guide on Tantillus.org?
Edited 1 time(s). Last edit at 08/02/2013 03:02PM by Nick101.
Re: Bed too low
August 02, 2013 04:03PM
> [www.makerfarm.com]
> -head-mk-iv-b-hot-end-for-3mm-filament.html if we
You may lose some of the build height with the Mk4 being longer if the two beds are not really close to each other.
The cable Z axis is designed with the Mk5's length in mind.
When I first designed Tantillus there was no Mk5 and it was designed to use the Mk4. But during the campaign I had the chance to try out a prototype Mk5 and liked the way it printed more than the Mk4 but found the length a little too short for the bed bolts so I had Hotends.com produce all my Mk5 hotends longer to work without having to make too many changes to the kits already being produced. Anyone self sourcing since has either used a longer hotend, longer bolts or the cable Z axis.
