IGUS Aluminium shafts
Posted by jfkoehle
September 20, 2013 06:20AM
Hi!
I'm building a metric T-Slot-Tantillus at the moment and just recieved 8mm IGUS aluminium shafts. In reality they are 7.94-7.96 so they fit quite (they are a bit too loose) nicely in 608-bearings...
Greetings
Jan
open | download - IMG_3993.JPG (166.8 KB)
Re: IGUS Aluminium shafts
September 27, 2013 01:26PM
progress...
September 27, 2013 08:52PM
Looks nice, I am curious to see how those shafts work out. How much did they cost?
September 30, 2013 05:38PM
What is the length of your horizontal and vertical 2020 beams?
Chuck
November 08, 2013 01:50PM
Have you gotten a chance to test fit the Igus plane bearings yet? I ask because those bearings/bushings are 16mm O.D. and the printed ones they will be replacing are 15mm O.D. Based on your shaft measurement I'm curious to know if, 1) you can compress the Igus bushings into the un-modified X-Y ends without breaking the printed part and 2) after compressing them appx. 1mm will you still have a compensated (not prescision) tolerance between the shaft and bushing recommended for a parallel shaft application by Igus.
