Re: Wingnut's build November 04, 2013 10:16PM |
Re: Wingnut's build November 04, 2013 10:36PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Wingnut's build November 04, 2013 10:51PM |
Re: Wingnut's build November 04, 2013 10:57PM |
Re: Wingnut's build November 04, 2013 10:58PM |
Re: Wingnut's build November 04, 2013 11:01PM |
wingnut
Oh.. and a note about 64bit Windows and configuration files. I figure out the cause of my earlier confusion regarding the placement of config files. It appears that, if you start Kisslicer with no config files, the defaults that are generated are put in $(LOCALAPPDATA)\VirtualStore. Once this happens, copying new files to the the location of kisslicer.exe has no effect because windows has redirected Kisslicer to the other path. However, if you delete the generated files, Windows resets this setting allowing Kisslicer to load the correct files. This is a security feature of 64bit windows..
Re: Wingnut's build November 04, 2013 11:19PM |
Re: Wingnut's build November 04, 2013 11:29PM |
wingnut
Oh.. So Extrusion Width is the parameter that drives the filament feed rate? Good to know.
Re: Wingnut's build November 05, 2013 09:25AM |
Re: Wingnut's build November 05, 2013 12:53PM |
Re: Wingnut's build November 06, 2013 01:09AM |
Sublime
Are you sure the correct filament is assigned to the extruder in the printer/extruders tab. Maybe you created a correct material profile for the 1.75 but you are not using it because the old one is assigned to the extruder.
Re: Wingnut's build November 06, 2013 01:23AM |
Re: Wingnut's build November 06, 2013 12:36PM |
Re: Wingnut's build November 07, 2013 01:15PM |
Re: Wingnut's build November 07, 2013 01:38PM |
Re: Wingnut's build November 08, 2013 12:28PM |
Re: Wingnut's build November 08, 2013 01:47PM |
wingnut
Trying to get a handle on what I need to tweak to improve accuracy. The cables are definitely due for some tightening. I also noticed some flexing in the acrylic last night. I can see gap in the seam between the sides that grows and shrinks with movement of the carriage. Tonight I plan on chemically bonding all the seams. How does the stiffness of the printed case compare to the acrylic? Worth switching?
wingnut
Been wondering also about what it would take to replace the gears in the extruder with belt drive. I would like to do this mainly to reduce the noise level. As it is now, the extruder is by far the noisiest thing on the printer. I like to work while the printer is running and if there are allot of retractions, it starts drilling into my head :-)
Re: Wingnut's build November 08, 2013 03:34PM |
Re: Wingnut's build November 08, 2013 03:54PM |
wingnut
Funny thing about belts is that it took me a three tries to find belts that I liked (this one's too long, that one's too skinny, etc). The last set I ordered came from China (read, cheap and slow shipping) so I ordered ten :-). I will be the guinea pig then and try to come up with a belt driven extruder.
Re: Wingnut's build November 08, 2013 04:09PM |
