Fan speed fix
Posted by Robonz
Fan speed fix
October 10, 2013 09:51PM
I found my fans would only kick in when I turned the fan speed above 245 or so. The reason this happens is a lot of brushless DC fans do not like being fed by a PWM (pulse width modulation) signal.
I fired my fans up from a smooth variable DC power-supply and found they did indeed change speeds nicely so this led me to a simple modification.
I connected/added a 47uF capacitor across the fan connections. It now adjusts speed nicely and runs very slow with a fan speed setting of 10 or so. If you do this modification make sure you connect the + and - of the capacitor to match the + and - on the board. The capacitor smoothes the PWM into a DC voltage, which most fans do like. If you find your fan starts at too lower value you can use a smaller capacitor e.g. 22 uF.
Disclaimer: Do this mod at your own risk!
Re: Fan speed fix
October 10, 2013 10:12PM
This is how all of mine are wired and how I recommend wiring them. But one thing is be sure to put a current limiting resistor before the cap or you could damage the FET on the Ramps. I use a 1ohm 1/4 or 1/2 watt resistor.
Edit: It is called an RC filter. You could also use an Inductor instead of the resistor.
Edited 1 time(s). Last edit at 10/10/2013 11:36PM by Sublime.
Re: Fan speed fix
October 11, 2013 12:25AM
@Sublime That sounds like a good safe approach. Seeing as the fan drive is open drain and not push pull and the ESR of my capacitor is not that low, I think things will be fine. If the fet blows up I will let you know. I still havnt done my first print on this Tantillus. Hopefully next week when I get my glass bed. I really like the low inertia design you have come up with.
Re: Fan speed fix
October 12, 2013 04:10PM
Also be sure to unplug the power or unplug your fan before you do this, I blew the FET on my Ulitmaker while soldering on a cap to the fan while the power was on. Oops. smiling smiley
Luckily they are cheap and it wasn't SMT so very easy to replace.
Re: Fan speed fix
October 15, 2013 08:28AM
Just to clarify. is like this? I don't want to break my RAMPS since it is SMD.
        FAN
    |         [=] inductor
        D9
Re: Fan speed fix
October 15, 2013 11:42AM
I would have the inductor on the positive.
                   FAN
    inductor  [=]         |
                   D9
