Uneven feeding December 10, 2013 03:12AM |
Re: Uneven feeding December 10, 2013 03:29AM |
Re: Uneven feeding December 10, 2013 04:06AM |
Re: Uneven feeding December 10, 2013 11:59AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Uneven feeding December 10, 2013 05:27PM |
Re: Uneven feeding December 10, 2013 08:56PM |
Re: Uneven feeding December 15, 2013 06:16PM |
Re: Uneven feeding December 15, 2013 06:22PM |
Re: Uneven feeding December 15, 2013 10:46PM |
Re: Uneven feeding December 15, 2013 11:56PM |
Re: Uneven feeding December 18, 2013 01:06AM |
Re: Uneven feeding December 19, 2013 05:15PM |
Re: Uneven feeding December 19, 2013 06:24PM |
Re: Uneven feeding December 20, 2013 12:34PM |
Re: Uneven feeding December 20, 2013 02:08PM |
Re: Uneven feeding April 08, 2014 03:36PM |
Re: Uneven feeding April 08, 2014 04:03PM |
Nick101
Hey guys,
Recently fired up my Tantillus again after a long hiatus and I'm still having a tough time with the first few layers of a print over-extruding (even with flow set ~ 320). I've tried setting flow to 300 with better success but once the infill layers start printing, the print looks under extruded, with small gaps between passes. At this point I bump the flow rate back up to ~375 and it seems much improved. Is there a way to implement some sort of variable flow rate depending on where the print is in completion? Would this be a reasonable solution or is there an underlying problem I'm not considering?
Re: Uneven feeding April 08, 2014 07:28PM |
Re: Uneven feeding April 08, 2014 08:22PM |
beekeg
I'm getting good adhesion with Power Pritt on blue painters tape. The flat top of the stick is also useful for flattening down the tape too. For large prints it may be necessary to soak the whole lot in water to release the tape from the glass and then the tape from the print.
Re: Uneven feeding June 23, 2014 07:40PM |
Re: Uneven feeding July 04, 2014 05:59PM |
Re: Uneven feeding July 04, 2014 07:27PM |
Re: Uneven feeding July 04, 2014 07:49PM |
Re: Uneven feeding July 04, 2014 08:11PM |
Re: Uneven feeding July 04, 2014 08:19PM |
