Unexpected X-axis offset issue December 31, 2013 12:14AM |
Re: Unexpected X-axis offset issue December 31, 2013 12:14AM |
Re: Unexpected X-axis offset issue December 31, 2013 12:36AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Unexpected X-axis offset issue December 31, 2013 01:04AM |
Re: Unexpected X-axis offset issue January 01, 2014 08:12PM |
Re: Unexpected X-axis offset issue April 14, 2016 07:50AM |
Re: Unexpected X-axis offset issue April 14, 2016 02:02PM |
Always put fans on. Especially on drv8825. Heatsinks are mandatory as Well.Quote
Andersl
I'm getting exactly the same issue on my newly built tantillus. Has someone else experienced this recently and if so what was the solution? I'm measuring the temps right now to find out if I'm hitting the thermal limits of the drivers. I'm using drv8825's
Re: Unexpected X-axis offset issue April 14, 2016 04:37PM |
Re: Unexpected X-axis offset issue April 15, 2016 12:33AM |
If you can't touch them with your fingers they are too hot. They shot Down completely at 80c but "throttles" way before that.Quote
Andersl
OK, I'll try that. The temperatures flattened out at roughly 70 degrees C on top of the chips during a lengthy print of two tantillus XY ends. Just blowing a fan on them reduced the temp to 45 degrees C. Does anybody know roughly at what temps the chips shut down. Obviously the temp on top of the chip is not the same as the one inside the chip but there is probably some correlation. I'm using chinese clones of the poll step sticks and set the Vref to roughly 700 mV which increases the temperature quite considerable compared to running them at 500mV.
I'm not so sure that my problem is related to overheating though as it seems to print nicely with my settings in Simplify3D, however, when I used Kisslicer with Sublimes profiles I get this shift. Maybe the motors skips steps when the speeds are higher. As of now I don't really know what printing and movement speeds you would expect from a spectra line driven Tantillus.
Re: Unexpected X-axis offset issue April 17, 2016 11:58AM |
Re: Unexpected X-axis offset issue April 18, 2016 04:16AM |
Well said. It was actually what I meant: recording your settings.Quote
robster34
Just to confirm what others have speculated...I had real problems adjusting the stepper current on my Tantillus printers. I use a variety of a4988 driver suppliers. Too little current and the motors wouldn't reliably follow the steps. Too much, and it would skip occasionally (particularly at high speed).
What eventually worked for me was to get very thorough about adjusting the current. I don't use heatsinks, but I adjust the current by measuring the voltage on the adjustment pot. Once I find a value that works, I record it, and set all the drivers at the same voltage. Sometimes it takes a couple days to get the right value, and I carefully record all the values I try so I'm not chasing my tail. I haven't had that problem in years now.
I use a variety of supply voltages, so my settings may not be adequate for you. Be diligent and careful, and I suspect you'll find a setup that's reliable.
Re: Unexpected X-axis offset issue April 18, 2016 11:19AM |
