Heated bed February 10, 2014 10:22PM |
Re: Heated bed February 11, 2014 02:47AM |
Re: Heated bed February 11, 2014 12:03PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Heated bed February 11, 2014 03:56PM |
Re: Heated bed February 11, 2014 07:14PM |
Re: Heated bed February 11, 2014 07:24PM |
wingnut
Interesting points Sublime. I will have to keep an eye on the arms. I'm confused about one point though. Why does a heated bed limit the amount cooling?
Re: Heated bed February 20, 2014 11:12AM |
Re: Heated bed February 20, 2014 11:36AM |
Re: Heated bed February 20, 2014 01:44PM |
Re: Heated bed February 20, 2014 02:21PM |
Re: Heated bed February 20, 2014 05:41PM |
Re: Heated bed August 12, 2014 06:58AM |
Re: Heated bed August 13, 2014 02:35AM |
Re: Heated bed August 28, 2014 12:43AM |
Re: Heated bed August 28, 2014 09:15AM |
Re: Heated bed August 28, 2014 09:45AM |
Re: Heated bed August 29, 2014 12:33AM |
SkyArcher
... I think that once you've laid down the first 5-10 layers, the heat is no longer needed.
Re: Heated bed September 01, 2014 06:10AM |
Robonz
For Kisslicer
M140 S0 turns off the heated bed, just stick that in ptr gcode-> N* layers set the layer number to the layer you want to turn it off at. I have not tested this but it should work.
Personally I leave it on for the whole print but if I was to turn it off I would run at least 20 to 30 layers at 100um layer height
Re: Heated bed September 01, 2014 08:20AM |
Re: Heated bed September 02, 2014 06:48PM |
