Z axis
Posted by mondo50m
Z axis
March 12, 2014 12:23AM
I have a request. If anyone has made the Tantillus with the Spectra 'Z' option instead of the lead screw, could you please post how this is put together? I would rather use the cable version, as it should be smoother. Thank you in advance.
Milt
Re: Z axis
March 12, 2014 12:58AM
Have you read through the Cable Z thread already? [forums.reprap.org]
It gives a list of parts needed and gives general assembly instructions. Is there anything in particular that you are unsure about?
Re: Z axis
March 12, 2014 09:54AM
It sucks getting old. Thank you very much.
Milt
Re: Z axis
March 12, 2014 11:56AM
Re: Z axis
March 15, 2014 05:16PM
OK, I am not able to get the routing of the cable done. Just a quick pencil drawing of how the cable is to be run.
Milt
Re: Z axis
March 15, 2014 08:52PM
How about these.
Re: Z axis
March 17, 2014 12:00AM
Got it!!! Could not figure out how I would drill a hole in the drum with the stepper shaft running through it. Now I know I do not have to. Thanks bunches.
Milt
Re: Z axis
March 17, 2014 10:05AM
OK, I have to admit stupidity. I have tried this the way the drawing is made, and the drum just spins inside the cable. Shouldn't the cable be attached to the drum in much the same way the cable is attached to the smooth rod on the X,Y axis? So that the drum creates a pull, pull action on opposite rotations of the drum? As I stated, the drum just rotates under the cable and does not move the Z axis at all. Sorry to be such a pain.
Milt
Re: Z axis
March 17, 2014 11:44AM
No worries. The cable has to be really tight. When you pluck it, it needs to play a high pitch note (musically tight). Basically you need to have the tensioner as loose as possible while making the cable as tight as you can using knots at that point. Then tighten the tensioner bolts to get the cable musically tight. You may need to release the tensioner after tightening and add some knots and retension until it stays musically tight.
Also it turns out the holes may not be necessary even on the upper metal rods as long as the cables are tight enough. Ingentis (a derivative of Tantillus) does not use holes in the upper rods.
Re: Z axis
March 25, 2014 12:19PM
Hello all and thanks Sublime for the continuous effort you put in improving this little marvel.
I am attempting my own build and I was wondering why you did not wind the spectra line directly on the Z motor shaft as, based on my very little knowledge of mechanics, it should give a better step/mm rateo.
Thank to anyone that will take the time to explain this to me.
Re: Z axis
March 25, 2014 05:46PM
I'll take a crack at it...
Guess 1), using sound linear motion design practice, the other side of the shaft should be supported by a bearing in that application, most motors that are readily available to rep-rappers world wide come with too short a shaft, or the shaft has a flat on one or both sides.
Guess 2), the distance that you can move an axis using cable drive is limited by the amount of cable you can spool on and off of your "bobbin". As the diameter of the shaft gets smaller for a given ammount of travel the number of wraps increases, until you reach a point where the wraps become both unmanageable, and they dramatically increase the angle at which the cable is deflected from where it attached to the carriage. If the angle becomes too great then the cable tension increases as you reach the end of both sides of your travel. This can do anything from causing your axis to deflect, to causing the motor to skipp stepps, to snapping the cable.
In looking at the diameter that sublime chose for the spool/bobbin it appears to me that the z-axis upgrade was designed to manage the cable angle for 150-200mm travel.
Anyway that's my best guess.
Re: Z axis
July 14, 2014 05:20PM
cns1
The travel is not limited, as whatever line you reel in, you reel out at the same time on the other end.
