Suggestions for improvement March 28, 2014 10:32AM |
KISS settings are: [Style] Skin Thickness: 1 Extrusion Width: 0.41 Number of Loops: 3 Infill Extrusion Width: 0.41 Infill: 25% Octagonal Layer Thickness: 0.15 Wipe and Destring checked Seam Hiding: 1.0 Loops: 36.25 mm/s Solid: 32.50 mm/s Sparse: 42.50 mm/s [Material] Diameter: 3 Temp: Main: 192, First Layer: 195, Keep-Warm: 130 Destring P/S/ W 5/5/10 Speed: 500 Min Jump: 1 Trigger: 5
Re: Suggestions for improvement March 28, 2014 01:04PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Suggestions for improvement March 28, 2014 03:01PM |
Re: Suggestions for improvement March 28, 2014 10:00PM |
Re: Suggestions for improvement March 28, 2014 11:08PM |
Re: Suggestions for improvement March 29, 2014 10:59AM |
maik
Looking at the settings now, when you say "retraction distance of 5mm", is that bot the prime and suck values?
Re: Suggestions for improvement March 29, 2014 10:04PM |
Re: Suggestions for improvement March 29, 2014 10:19PM |
