Print Quality Pointers March 29, 2014 01:56PM |
Re: Print Quality Pointers March 29, 2014 04:13PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Print Quality Pointers March 30, 2014 02:06PM |
Re: Print Quality Pointers March 30, 2014 05:17PM |
Re: Print Quality Pointers March 31, 2014 03:45PM |
Re: Print Quality Pointers March 31, 2014 05:53PM |
Re: Print Quality Pointers April 01, 2014 06:29AM |
Re: Print Quality Pointers April 01, 2014 02:57PM |
Robonz
I printed that elepant and I can see why the glass would shift. Because it has some quite steep overhangs it likes to curl and then the head smashes into the curl. Tips on getting less curl would be welcome. I printed another one with the fans running much slower and it I got less curl and less head collissions, is that expected? does high fan speed make more curl?
Its a cool print by the way. It got dibs straight away.
Your print looks pretty good. I think mine is roughly the same in quality.
I can understand those Mendel machines have Z issues if they have two steppers in parallel. The back emf of the motors upset the microsteps I experimented with steppers in parallel. Each motor should have its own driver so the constant current can work properly.
Re: Print Quality Pointers April 01, 2014 07:26PM |
Re: Print Quality Pointers April 06, 2014 05:45AM |
Re: Print Quality Pointers April 06, 2014 05:35PM |
Re: Print Quality Pointers April 07, 2014 02:30PM |
beekeg
I used mm/s
loops=24
Solid=21
Sparse=31
I find that if I use higher speeds there is a risk of axis screws loosening. I guess I should check before each print, as something always goes wrong when I push the envelope speed wise.
Re: Print Quality Pointers April 08, 2014 07:12PM |
wingnut
Going to assume you mean mm/s :-)
Re: Print Quality Pointers April 08, 2014 08:23PM |
beekeg
tried the hairdryer tip to level/free up the z-axis and it worked a treat
Re: Print Quality Pointers April 20, 2014 06:33AM |
Re: Print Quality Pointers April 20, 2014 11:54AM |
Re: Print Quality Pointers April 20, 2014 01:00PM |
Re: Print Quality Pointers April 21, 2014 05:08AM |
Re: Print Quality Pointers April 21, 2014 02:39PM |
Re: Print Quality Pointers April 21, 2014 02:56PM |
wingnut
Sublime
What speeds are you printing at? I find higher speeds give a better outer finish.
Did you mean *lower* here?
Re: Print Quality Pointers April 22, 2014 02:06PM |
Robonz
If you are using a threaded rod for your Z lift you can try my z wobble hack. its a really quick easy upgrade. I would be interested to see your feedback.
As robster said, you are definately getting an x or a y shift that can be seen clearly above the elephants eye. I would make sure the x and y are really smooth. Turn it by hand with the power off. If there are any bumps or stiff points you need to resolve them. Also with the motor current, I just turn them up as high as I can get away with. If the stepper drivers are not too hot to hold your finger on you prolly need to turn them up. If they are too high you will get thermal cut out., e,g. the motors will shut off every couple of seconds. I set them to where I can just hold my hand on the heatsink and then turn them up a little more.
As far as the extruder goes. Have you got the big die springs as WWFP designed in? His mod works great. Its in the metric edition hacks on github.
Cheers
Keith
Re: Print Quality Pointers April 22, 2014 04:44PM |
Re: Print Quality Pointers April 23, 2014 01:51AM |
Re: Print Quality Pointers April 23, 2014 11:59AM |
Re: Print Quality Pointers April 23, 2014 06:28PM |
Re: Print Quality Pointers April 24, 2014 08:24AM |
Re: Print Quality Pointers April 24, 2014 01:58PM |
Re: Print Quality Pointers April 25, 2014 03:25AM |
Re: Print Quality Pointers April 25, 2014 12:47PM |
Re: Print Quality Pointers April 27, 2014 06:05AM |
