Build instructions only for the laser cut version
Posted by LucasGelf
April 07, 2014 10:23PM
It seems like the build instructions were only for the lasercut version. Are they the same instructions? Are there instructions for the printed version somewhere?
Re: Build instructions only for the laser cut version
April 07, 2014 10:35PM
LucasGelf
It uses the exact same parts except for the case. So everything goes together the same way except the case which you will find a one piece assembled stl in the file repo you can use to view the assembled case in 3D. There are also pictures in this folder [github.com] as well as exploded view pictures here [reprap.org] . There is more info here [reprap.org] and [reprap.org] that should also help.
Edited 1 time(s). Last edit at 04/08/2014 11:58AM by Sublime.
