Yet another question about self-design May 21, 2014 11:21AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Yet another question about self-design May 21, 2014 12:27PM |
Ohmarinus
Question no. 1 is about size.
I see a lot of tantillus' that have small print surfaces, why is this?
Is it because the smooth rods will hang when they get too long? Is the printer less accurate if the X and Y sizes are increased?
My goal would be to get a 200x200x150 printing area. I never printed higher and height is not important for me. If something is tall I usually cut it in half and glue it after printing.
The frame will be made out of aluminum extrusions, because I like how it looks. However, it can be smaller than the usual 20x20 extrusions used for a Mendelmax 1.5 but it might also be constructed of 4 to 6mm acrylic plates or very thin aluminum plating 2 or 3 mm thick. As the surface and corners will provide rigidity.
Is there an official model for the Tantillus or a shop that sells premade frame kits that I can take a look at? I found one shop on tantillus.org but their shop is closed.
After thinking a lot what to do, I now realise that it's no use to design a new Air2 frame for my old air or to try and improve the MendelMax. No, the whole Tantillus setup of X,Y and Z is so incredibly rich in advantages that this will be the best idea.
Hope to join here soon with my own Tantillus!
- Marinus
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Yet another question about self-design May 22, 2014 01:03AM |
Re: Yet another question about self-design May 24, 2014 10:17AM |
Re: Yet another question about self-design May 24, 2014 12:05PM |
Re: Yet another question about self-design May 24, 2014 02:39PM |
Re: Yet another question about self-design May 24, 2014 03:03PM |
Re: Yet another question about self-design May 24, 2014 03:22PM |
Re: Yet another question about self-design May 24, 2014 04:31PM |
Re: Yet another question about self-design May 24, 2014 05:39PM |
Re: Yet another question about self-design May 25, 2014 05:02AM |
Re: Yet another question about self-design May 25, 2014 02:11PM |
Re: Yet another question about self-design May 26, 2014 01:43PM |
Re: Yet another question about self-design May 26, 2014 03:45PM |
Re: Yet another question about self-design May 26, 2014 08:40PM |
Re: Yet another question about self-design May 27, 2014 02:40AM |
Re: Yet another question about self-design May 27, 2014 06:30AM |
Re: Yet another question about self-design May 27, 2014 07:54AM |
Robonz
As Sublime said the strings work and work without any issues if built properly. What I don't like about the stings is the time it takes to pull them on and off the machine if you want to do some maintainance. e.g if you needed to remove a shaft or bearing and put it back. But I do believe you get better performance with strings than belts because they are less stretchy than a belt.
To answer your question earlier. When I get new shafts I clean them down with isopropyl and a rag. I also chamfer the ends and most importantly straighten them. .When the machine is fully assembled I then lubricate the shafts. I also found that some skate bearings fit much better than others so its good to have a few "different" sets on hand.
Cheers
Keith
