What are Tantillus folks using other than Kisslicer? June 01, 2014 09:04AM |
Re: What are Tantillus folks using other than Kisslicer? June 01, 2014 12:01PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: What are Tantillus folks using other than Kisslicer? June 01, 2014 09:42PM |
Re: What are Tantillus folks using other than Kisslicer? June 01, 2014 10:04PM |
ronderful
Thanks Sublime.
In Kisslicer, I changed the temperature and fans speeds on the material tab, but it doesn't seem to take - temperature defaults to 220 (M104 S220) in the gcode, and the fan speed at 64 (M106 S64). Plus Kisslicer drops in M107 almost every layer or so, so the fan spins up and spins down almost every layer.
I'm running it on Mac, so not sure if these issues are specific to this OS.
I actually use Simplify3D for other printers with great success, but didn't think about using for the Tantillus because it lacked bowden related features (at least when I first started using it). It seems I was a few releases behind, and looks like
it does support them now (for rostock etc). I'll give the latest version a whirl...
Re: What are Tantillus folks using other than Kisslicer? June 03, 2014 12:29AM |
Re: What are Tantillus folks using other than Kisslicer? June 10, 2014 09:25AM |
Re: What are Tantillus folks using other than Kisslicer? June 10, 2014 12:01PM |
Re: What are Tantillus folks using other than Kisslicer? June 11, 2014 10:01PM |
Re: What are Tantillus folks using other than Kisslicer? June 11, 2014 11:23PM |
MrDoctorDIV
Haha, yeah. I like things that are simple to use. A few tries at Kisslicer and I was out. I'm an easily lost customer, you can imagine. Beg as you might, if I don't like your product I'm not buying it [or using it, in the case of free software].
Re: What are Tantillus folks using other than Kisslicer? June 24, 2014 03:20PM |
Re: What are Tantillus folks using other than Kisslicer? June 25, 2014 01:55PM |
