first connecting to mac June 30, 2014 08:37AM |
rinter stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
D init fail|
Re: first connecting to mac June 30, 2014 11:12AM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: first connecting to mac June 30, 2014 11:39AM |
Re: first connecting to mac June 30, 2014 11:58AM |
Re: first connecting to mac June 30, 2014 12:27PM |
Re: first connecting to mac June 30, 2014 02:25PM |
Re: first connecting to mac July 01, 2014 03:46AM |
Re: first connecting to mac July 01, 2014 03:57AM |
Re: first connecting to mac July 01, 2014 12:00PM |
Sublime
For the thermistor in Marlin you change line 61 of configuration.h to match which ever thermistor you are using from the list (lines 47-59). If your thermistor is not listed you may need to add it to thermistortable.h (you are most likely able to copy it from a newer version of Marlin).
If you read the instructions it tells you to adjust the current until the motors move and then adjust it a tiny bit if it makes a high pitched noise until it stops making the noise. By using this method you run the motor at the lowest current it will run and with the adjustment for noise you ensure the current chopping circuit is running as close to sinusoidal as possible.
If you simply adjust them based on the vref you could be running the motors much hotter than needed and it can even cause it to skip the microsteps and not move smoothly.
Re: first connecting to mac July 03, 2014 12:32AM |
Re: first connecting to mac July 03, 2014 01:35PM |
Re: first connecting to mac July 05, 2014 05:45AM |
mdcompositi
Sorry!!!
problem solved for the moment about termistor!!
bad location as you say!!!!!!!!!!!!!!!!!
about the motors I'm waiting to change drivers, also I think that they are bad (A4988 green colour)
I'm waiting for that
[reprap.org]
I have them mounted on my Prusa and i3 are fine!
As soon as I arrive I see what happens and let you know!
thanks for your time and congratulations for your work
Re: first connecting to mac July 05, 2014 01:46PM |
Re: first connecting to mac July 05, 2014 01:47PM |
Re: first connecting to mac July 05, 2014 06:58PM |
Sublime
The power supply looks fine. I run my Tantillus off of 15V to allow a little faster step rates as well as faster heating times but other than that yours should work fine.
The motors are not correct. Although they are the correct current (1.7A) they are not the correct resistance or voltage. We want about 1.65ohms of resistance and you have 30ohms. We want the lowest voltage motors you can get (usually around 2.8V) and you have 12V motors. Both of these means unless you have a high voltage power supply 24-30v you will not be able to reach the rated amperage unless you step extremely slowly and even then the drivers will most likely not like it.
Re: first connecting to mac July 05, 2014 06:59PM |
Re: first connecting to mac July 05, 2014 09:33PM |
mdcompositi
Sublime
ok,
can you suggest me right motors to use?
please send me technical details about?
Re: first connecting to mac July 08, 2014 12:02PM |
Re: first connecting to mac July 08, 2014 02:15PM |
mdcompositi
Finally I solved all problems and now my Tantillus works!!
I'm trying to make a first printing but I have a problem I can not solve!
in practice when I start a print job, the z-axis instead of going down as the machine completes a layer, remains firm on the same
I realized that I need to do a setting of the z axis in the software that runs it but I can not find the right option!
But I have installed Repetier host because I was more practical!
Can you suggest me a solution?
other question!
can I buy this power supply?
[www.ebay.it]
Re: first connecting to mac July 09, 2014 06:51AM |
Re: first connecting to mac July 09, 2014 11:37AM |
Re: first connecting to mac July 09, 2014 12:19PM |
Re: first connecting to mac July 09, 2014 03:25PM |
mdcompositi
#define DEFAULT_MAX_FEEDRATE {150, 150, 15, 40}
Re: first connecting to mac July 10, 2014 10:18AM |
Re: first connecting to mac July 10, 2014 10:52AM |
mdcompositi
I changed the speed setting 5 but the same does not change anything!
I use slic3r
Re: first connecting to mac July 10, 2014 01:22PM |
Re: first connecting to mac July 10, 2014 01:33PM |
Re: first connecting to mac July 10, 2014 03:23PM |
Re: first connecting to mac July 10, 2014 10:31PM |
Re: first connecting to mac July 11, 2014 04:46AM |
