Created some Tantillus Compact Ultimaker Slider Adapters March 16, 2016 10:39AM |
Re: Created some Tantillus Compact Ultimaker Slider Adapters March 16, 2016 02:31PM |
Re: Created some Tantillus Compact Ultimaker Slider Adapters March 16, 2016 04:15PM |
Re: Created some Tantillus Compact Ultimaker Slider Adapters March 17, 2016 12:09PM |
Re: Created some Tantillus Compact Ultimaker Slider Adapters March 17, 2016 12:35PM |
Depends a bit on compared to what? I have never used the original, as I'm not a fan of thread and knots in my printer.Quote
Martin_H
Those are neat mods. What's the advantage of the lead screw modification?
Re: Created some Tantillus Compact Ultimaker Slider Adapters May 27, 2016 02:12AM |
Re: Created some Tantillus Compact Ultimaker Slider Adapters May 27, 2016 04:41AM |
If you want to make it bigger, you might as well use the Ultimaker 2 Go design insteadQuote
leonal
that's really useful , we can have compatible ultimaker carriage used in tantillus now! but the print volume is reduced , that's not good , I hope i can have a large tantillus (about 16cm*16cm*16cm) with compatible ultimaker xy carriage.
Re: Created some Tantillus Compact Ultimaker Slider Adapters June 05, 2016 03:07PM |
Re: Created some Tantillus Compact Ultimaker Slider Adapters June 05, 2016 03:09PM |
There's a link to the carriage in the description of the sliders: [www.thingiverse.com]Quote
plexer
What is the actual carriage you are using there? is it on thingiverse?
Thanks
Ben
Re: Created some Tantillus Compact Ultimaker Slider Adapters June 05, 2016 03:18PM |
Re: Created some Tantillus Compact Ultimaker Slider Adapters June 06, 2016 12:18AM |
