After placing the granite slab under blade, it will be aligned well with mark where the stone will be cut. Later, for using best
bridge saw granite, you have to power up water tank and check free flowing nature of it. So, if you are actually heading for the best Bridge Saw for Granite cutting practices, head towards the bridge saw first, check on the options and then make way for the right solution.
