A few things to check:
- the slicer configuration: is there a Z offset configured to 7mm in the printer settings ? are there special command, like a Z offset, inserted in the GCODE every time it's exported ?
- the Z endstop: Is it firmly positionned ? Is it responding correctly to manual input ? The print should start by two Z home probes, one at high speed, one at very low speed. When does the Z moves 7mm up in this process ?
- the firmware: are you using the firmware that Emmanuel loaded on the card, the one from the github, something else ?
Tom
